ccm r30
Topic Started: May 9 2018, 03:58 PM (114 Views)
woz
hello, iv had my ccm for a few years now...generally use it around the farm and the odd blast round the lanes.....iv come to it this season and it wont start.when i wind it over it fires for a second then just winds over...if i hit the start button again it fires and then cuts out....its the suzuki engine......iv had the plugs out and cleaned them and also taken the carb off it,which looked clean in the bowls and jets?????
kind regards warwick
wirral121
I,ve found that a bike that has not been used for awhile the pilot jet holes blocked, they are tiny are you sure these are not blocked as I,ve found this on a few bikes in the past cleaning/or replacing them has cured the problem.
woz
weve tried running it on sniff and its still the same...could it be crank sensor???
« Previous Topic · Welcome · Next Topic »
