Suzuki B100
Topic Started: Mar 31 2018, 01:51 PM (217 Views)
Othen
I thought subscribers might be interested in this one. I bought a 1976 Suzuki B100 (120cc) as a barn find from a breakers yard 2 years ago. It was in a bit of a state: pretty rusty, non-running engine and someone had (probably 30 years ago) tried to hot wire the bike and so ruined the ignition lock (which was a pity as the bike would have been trivially easy to hot wire without damaging anything). It was cheap (from a breaker's yard) and although not really my sort of thing, it was too good to let die.
The bike came with the original bill of sale and the white type log book, but had never been scrapped. The story was it was bought by the first owner in 76, he rode it for 10 years and did 15,000 miles then suddenly stopped using it is 86 (the last tax disc is still on the bike), pushed it to the back of the shed and bought another bike for his commute to the shoe factory.
I thought I might just get it running and riding as a winter project (remember, that was 2 years ago). A bit of welding saved the rusty swing arm, I found a new switch and key (brand new, amazingly exactly the same item is still fitted to some bike or another that is still in manufacture) and re-wired the bike one afternoon. The engine would turn over by hand, but to be safe I thought I'd better strip it down to find out why the bike had stopped working in 1986. As I did I found the right (drive) side main bearing had disintegrated completely...
... the engine/gearbox strip down was not too difficult and all the bits I needed (mainly bearings and gaskets) were surprisingly still available and quite cheap. Having got everything back together the first time, I found the kick starter pawl still in my box of bits - and so had to take most of it apart again to put it back in the right place!
The engine turned over nicely now (and the top end was fine), but I thought I'd better work out why it had suddenly stopped in 1986. I found the answer whilst inspecting the auto-lubrication system. Someone had replaced the check valve that injects oil into the crankcase with an ordinary hydraulic union, as you may see from the nail inserted into it, this item has no one-way valve to stop the crankcase pressure forcing oil back against the pump:
So, that is why it failed. The new check valve was still available (new) and has sorted that problem. The rest was just getting rid of the worst effects of 30 years unused in a shed: most of the chrome had peeled off and so I painted over with some mat black to stop any more corrosion, the frame got a quick rub down and a coat of lacquer and the exhaust was roughly repaired (with plates, rivets and exhaust paste). A new set of points and a plug had the thing running, and to my surprise the cycle parts were more or less okay (with a bit of grease and fettling). I had no intention of a full restoration, but the bike had been saved so I sent off to DVLA and got a new V5. The 'sort of' finished bike is here:
That takes up to this time last year, where the running and riding project got pushed to the back of the garage and my Triumph Scrambler moved to the front for the summer season (I'm a fair weather rider). There the bike stayed until last week when I noticed it whilst working on my recent acquisition (CCM CXR230 - see my other thread). Once the CCM was through the MoT I ran out of things to do, and so tried to start the Suzuki. The battery (a tiny 6v affair) had died some time in the last year. A replacement arrived in the mail this week, I charged and fitted it this morn, gave the plug a clean and the B100 started after about 4 kicks. I smokes like a 40 a day man of course (like all 2 strokes from the 70s - but I also run this one on a weak 2T mixture just to be sure), but it runs okay and rides (as far as the end of the cul-de-sac and back), the gearbox changes, the brakes stop and the clutch clutches.
I noticed the lights are a bit dim (there is not much of an error budget with a 40 year old 6v system) so I'll pick up a tin of contact cleaner this week and have them gleaming (well, perhaps glimmering) pretty soon.
I don't think I'll do any more to the bike than that. I've achieved my aim and I'm not interested in a full restoration. The bike will become tax and MoT free next month (I think it would pass an MoT once I've sorted out the earth returns with the tin of contact cleaner, but there is no point as it will be MoT free in a month or so). At that point I think I'll look for a good home for the bike.
Edited by Othen, Mar 31 2018, 04:21 PM.
I had a B120 engine in a go kart I built many moons ago, bought the whole bike for 35, ripped rear wheel apart and used the brake hub on the rear axle of the kart.
Lardmarc
Jester
Mar 31 2018, 06:00 PM
Ripped rear wheel apart and used the brake hub on the rear axle of the kart.
Snap.........I did the same same with an old RD200. My engineering skills weren't up to much back then, the way I fixed the hub to the axle broke occasionally leading to some hilarious/ hairy moments.
Just a flunky along for the ride.
Othen
B120 in a kart - marvellous!
Othen
I don't know whether this link to the B120 running will work:
https://1drv.ms/v/s!Ask6E_1jz4xIskb-lEyqgdOTrHLE
... if someone would try it and let me know whether it works over the 'net I'd appreciate it.
Edited by Othen, Apr 1 2018, 06:12 AM.
Worked for me, nice one
Othen
Apr 1 2018, 06:58 AM
Many thanks, that is good.
Alan
Lardmarc
Jester
Nice. I like an 'oily rag' finish.
Well done.
Othen
Lardmarc
Apr 1 2018, 10:37 AM
Well done.
Thank you.
I was just talking about it with my 13 year old son, and mentioned that perhaps we would sell the Suzuki on to a good home after 20 May (when it becomes tax and MoT free, so ownership will be even less onerous). To my surprise Dan said he really liked the bike, and asked if we could keep it. Well, it is really cool having a 42 year old bike - particularly one with a 42 year patina, and I have a soft spot for it so perhaps we will keep it after all.
I agree with you about the oily rag finish (a good description), the only thing the bike really needs is a new header pipe, which is still available from the USA at about 70 delivered (or perhaps I just do a much neater patching job on the original, which might be more in keeping with the rest of the bike than shiny new chrome and a good excuse to buy a MIG welder).
Alan
Edited by Othen, Apr 12 2018, 06:51 AM.
Lardmarc
Jester
'Oily rag' is my favourite build, you don't spend much time cleaning it after a ride.
Othen
I ran the B120 up the other day only to find it leaking heavy oil from the exhaust. Obviously the crankcase seal on the drive side has failed in the year it has been standing. A new 47mm seal arrived in the mail yesterday (cost about a fiver) and I'll put it on in the next week or so. I think I recall it is not too hard a job: just remove the oil pump and clutch, take off the pinion bolt and pull out the spacer from the middle of the seal, then drive the new one in and re-assemble.
Something always goes wrong when working on 40 year old machines though - so I'll allow myself half a day :-)
You will also probably need a new gasket
Fallsoffalot
My first 'proper bike' was a brand new b100p. Loved it. Road from Norfolk to Somerset & back. Before that I had a Raliegh runnabout.
And yes the lights were crap.
« Previous Topic · Projects · Next Topic »
