Sprocket bolt pattern? (PCD)
Topic Started: Feb 3 2018, 01:02 PM (267 Views)
Joemi
I have a ktm 250 EXC that has CCM 404ds supermoto wheels fitted.
I'm just wondering if anyone knows the PCD of the rear sprocket and what other sprockets will fit?
the 644 is the same wheel, so talon will do them, what size are you after?
Talon part number is T124 43 (number of teeth) 525 (chain size)
Joemi
Feb 3 2018, 02:26 PM
I'm after a 45T but in a specific brand, I need a supersprox stealth sprocket which they don't supply for CCMs.
This is why I need to know which other manufacturers use the same PCD
Edited by Joemi, Feb 3 2018, 11:49 PM.
If you go to the talon site and look for the part number, It may have the dimensions you need
