644DS Non starter - help; Bike wont start and im sh*t with electrics
Topic Started: Oct 8 2017, 01:10 PM (1,023 Views)
Neillds
Okay my trusty 644 DS decided its not going to start, have charged the battery still nothing have neutral light, the two relays behind the os cover click but nothing? clues/help would be much appreciated
Have you knocked the kill switch over, that feeds the electric start button if off, that is if both relays are energising, one is side stand other is ignition, the ignition feeds start button via side stand relay and is fed by the 10a fuse in the middle of fuse box
Neillds
yes I checked kill switch, also noticed when I turn the ignition on theres like a high pitch but quiet wine coming from the relays?
swop them over
Neillds
yes I did try that, could they both be knackered? think my side stand switch isn't connected ( and never has been)
have you checked the fuse
Neillds
yes checked and changed it just to be sure, I remember why I hate electrics!!
you will need a volt meter now to check things, I've given you the easy things to check, try the plug behind the headlight that goes to the start button, make sure all the pins are in place, sometimes they get pushed out and dont make a connection
Neillds
ok, thanks ill have a look tomorrow night, weirdly I do have a voltmeter, just got to work out how to use it!
Neillds
right I removed headlight and pulled apart all plugs and reconnected them, still the same??
what do I check next with the multimeter, can I check the relays with it, sorry if that's a dumb question?
the 4 pin plug that goes to the starter switch and kill switch, pull apart with ignition on, you should have a 12v supply on the bike side of the plug, if not check the side stand relay is working
Neillds
ok i have current the bike side of the connector, what can I check next?
Interestingly one of the relays is now making a noise like a high pitched buzzing with ignition on
relays should not do that, have you taken them out and cleaned up the pins, plus squirt wd40 into the socket. I then twist the relay pins slightly to make them fit real tight
relays should just click, on or off.
woodcarver
Sounds like a dodgy neutral.
Neillds
well tonight i put in a new relay from Haines and still the same!!
When you say dodgy neutral can you elaborate please, what should I check next?
where in the country are you? bring it to me and I'll sort it, Essex.
Neillds
Sadly I don't have a van to get It to you, I'm in Kent just near Brands Hatch
Ill ask around and see if I can blag one
Very generous offer though thanks
You are not that far away then, can you not hire a van, Neil who came to wales this year did, it was silly money, just over a ton for the week I think, Any day of the week is fine, just give me a days notice
I'm in Tiptree, get off A12 at Kelvedon
Edited by Monty, Oct 13 2017, 07:54 AM.
woodcarver
Cheapest way is look on comparison sites many weeks in advance cos rates change daily. Or the next day or same day for a good rate.
woodcarver
Oh the neutral from relay to battery.
Go to Next Page
