Rear shock rebuild
Topic Started: Aug 11 2017, 04:20 PM (149 Views)
Rotax-mark
Looking at getting my shock rebuilt off my 604, the shock is fine but looks tired, just want it tarted up so it all looks nice.
Any suggestions on reasonably priced places that'll do a good job?
Thanks.
Are you looking just to tart it up or get it serviced as well? easy to tart up remove and get spring powder coated 20ish, attack rest with soft wire brush and polish
Online Profile Quote Post Goto Top
Rotax-mark
Just tart it up tbh, are they easy to disassemble?
Easy if you have a shock compressor to get the spring off, car spring compressors work but can damage the spring coating when reassembling,
vinny900
Maybe time to get the rear shock serviced - with new oils and seals etc. I didn't realise until recently but you should change rear shock oil at least every 5 years.
Not sure it is a DIY job though as some special tools are needed and after the rebuild the shock has to be filled up with nitrogen
