| Ccm speedo conection to brake calliper bracket; Ccm 644ds speedo mount issue | |
| Tweet Topic Started: May 24 2017, 03:43 PM (1,921 Views) | |
| CcmGyp | May 24 2017, 03:43 PM Post #1 |
Hi guys, I'm after some advice. Today I fitted the off road wheels to my ccm644ds 2005. I have an issue with the speedo, I don't know if it's standard but my speedo cable screws straight into the original caliper bracket and is just a plastic thread, on the off road wheels bracket there isn't a hole for it so can't use it with those wheels. This doesn't seem right reading the posts on here. Any advice would be much appreciated!! |
| woodcarver | May 24 2017, 08:37 PM Post #2 |
Standard ccm speedo is mechanical is yous digital. |
| Monty | May 25 2017, 09:37 AM Post #3 |
Later bikes had a digi speedo fitted, so you need a offroad bracket with the extra hole to mount the speedo pickup, plus you will either have to mount a speedo drive to act as a spacer so the wheel fits correctly, or get a spacer made up, I have dimensions here I'm sure so could make one. |
| Tramp | May 28 2017, 08:04 PM Post #4 |
Easiest fix is a cycle speedo...or a satnav...both a road legal just check calibration for different wheel size |
| CcmGyp | May 28 2017, 09:43 PM Post #5 |
Yeah it's a 2005 with a digital speedo! To be fair it's pretty flimsy, can I attempt to attach it to the talon caliper bracket somehow!? Does it have to be in a precise place to pick up the speed?? I just want to keep the miles legit but to be fair i predominantly have the road wheels on!! Cherrs |
| woodcarver | May 29 2017, 10:06 AM Post #6 |
there is a small sensor magnet around the disc brake area on the wheel. |
| lahauteur | May 29 2017, 10:24 AM Post #7 |
Rider
When I put a digital speedo on mine for my off road wheels I made a small dog leg bracket to mount the sensor from the lower caliper bolt. Mounting on the upper bolt may well have protected it better but it hasn't been damaged so far. |
| 2001 Rotax 640e Supermoto and 1998 350 Enfield Bullet. | |
| CcmGyp | May 31 2017, 09:18 AM Post #8 |
Cheers for the help guys!! Probably just live with it as only really use road wheels!! |
2:45 PM Jul 11
