Wheel bearing removal
Topic Started: Jan 11 2017, 05:48 PM (281 Views)
Barns
Hi guys I'm going to remove the wheel bearings from my AJP hub equipped 604 off road wheels. As I cannot see a hole in the spacer between the bearings what is the trick for removing the first bearing. Cheers guys
prize out oil seals
on one side is a massive circlip, remove that
i use a long narrow punch/drift/brass bar to tap the spacer tube to one side (on the bearings on the upside)
then turn the wheel over
use the punch/bar to tap the bearing out, as you can get on the bearing now
i work in circles to tap it out
hth
woodcarver
As you're a man in the know rob is there any rules about changing the bearings in my gasser.
Barns
That's my job for the weekend. Help avoid the grandkids ( monsters )😜
motopsycho87
woodcarver
Jan 12 2017, 03:35 AM
Make sure the inner bearing on the gasgas connects inner race to inner race. Many have been destroyed.
Tramp
Repack new bearing with grease and put in freezer overnight to make fitting so much easier....the circlip is the hard part...if you dont have correct pliers its hard lol....
woodcarver
will be the same if theyre AJP hubs
or may not have the circlip
but all pretty similar on these bikes
some hondas have weird 50mm aluminimum threaded locking nut affairs that are a pita
