| Top end overhaul; Rotax issues | |
| Tweet Topic Started: Oct 9 2016, 12:21 AM (492 Views) | |
| Tombs | Oct 9 2016, 12:21 AM Post #1 |
Morning gentlemen. Got a wee problem. Suspected burnt valves on the rough rotax. So I'm just gonna whip the head off for my own peace of mind. Valve clearances were set at 0.05 which as far as I'm concerned is too bloody tight and as a result think the valve seats are a bit Krispy... only getting 108 on comp test. And being a pernickity bastard can't get the fucker to run to my satisfaction. If I can build chevy engines cranking 400 plus horse I refuse to be beaten by my rotax lol. Any advice is appreciated. Oh and the initial point was where can I get a top end gasket set? |
| Monty | Oct 9 2016, 07:34 AM Post #2 |
The rotax uses O rings, no gasket, O rings for sale in for sale section. I always lap the head and barrel mating surfaces in as well, I also set my valves at 4 thou in 6 thou ex, never had any probs, Gary at sportax does set his at 2 thou which is what the manual states You may have to remove the engine mounts and starter motor, so the engine tilts as far forward as it can to get the head free, I'd also do the stem seals at same time, Gary will have these |
| Tombs | Oct 9 2016, 02:08 PM Post #3 |
Excellent. Thanks bud. This f****r will run and it'll bloody well run properly |
| Ant P | Oct 9 2016, 07:12 PM Post #4 |
Whats best used to mate head and barrel surfaces? Heard rumors of hylomar? But never used it? |
| Gonzo250 | Oct 10 2016, 03:40 AM Post #5 |
Don't need any goop to stick head and barrel together. As Monty says, spend a bit of time with some fine grinding paste and lap them together, job's a good'un. |
| Monty | Oct 10 2016, 05:37 AM Post #6 |
you dont use anything, Just 3 O rings |
| Ant P | Oct 13 2016, 10:16 AM Post #7 |
Cool. Thank you |
| Tombs | Oct 15 2016, 08:44 PM Post #8 |
It's alive. And it won't wheelie. Just shreds the back tyre. Good fun |
| Tombs | Oct 17 2016, 04:15 PM Post #9 |
Okay new development... it is pumping oil up out the clutch cable tube on the clutch case.... any ideas? |
| Monty | Oct 17 2016, 06:03 PM Post #10 |
either the O ring has gone on the cable, or you have too much oil in the bike, or your breather is blocked |
| Tombs | Oct 17 2016, 09:58 PM Post #11 |
Aye well it is literally pumping the fuck out. The oil is halfway up the sight tube on the frame when it's running |
| Gonzo250 | Oct 18 2016, 12:43 PM Post #12 |
Check breather from rocker cover to frame, and I believe there''s one by the generator cover behind the sprocket cover. |
| Sportax Racing | Oct 20 2016, 08:51 AM Post #13 |
You need one of these... http://sportaxracing.co.uk/shop/mt-parts/clutch-cable-boot-kit/ or maybe a new cable... If i dont cork the hole off when an engine is on the test bed oil is soon spraying out of the hole... |
