| front brake switch 604 | |
| Tweet Topic Started: Sep 3 2016, 09:48 AM (227 Views) | |
| stevo604 | Sep 3 2016, 09:48 AM Post #1 |
I am after a front brake switch not the round push in one but the square type on the later model . any idea what they are of cant find one on ebay or are they of any other make ktm yam etc etc cheers stephen |
| Rob 110 | Sep 3 2016, 11:19 AM Post #2 |
what the 2007+ KTM/Brembo one? If so its Genuine only :( part no:50311050100 £36.66 !!! so: A rear brake switch is less than half the price and plugs straight in, but check that your bar bend and handguards will allow space for a banjo bolt switch. http://www.ebay.co.uk/itm/M10-x-1-00mm-Brake-Pressure-Switch-Light-Banjo-Bolt-Honda-Kawasaki-Yamaha-Suzuki-/182240481820?hash=item2a6e61121c:g:ahAAAOSwdsFUPd-8 or a genuine KTM rear with a 90degree cable exit is about £15 tbh i just went with the £35, ok it was £25 more but couldn't face a long hour rebleeding after fitting a rear switch hth |
| stevo604 | Sep 3 2016, 11:46 AM Post #3 |
cheers for that info rob will have to check what space I have for a pressure switch. seen the brake switch on a German ebay at 15 quid going to check it out for postage I will stick the link up later cheers |
