| Re-spraying alloy rims?; Any tips on DIY wheel spraying | |
| Tweet Topic Started: Oct 27 2012, 10:59 AM (563 Views) | |
| chimaira | Oct 27 2012, 10:59 AM Post #1 |
Looking to change the colour of my 3spokes on my r30 and trying to keep costs down so rather than pay for professional refurbs I'd like to do it myself, had a dabble of body work on my minis in the past. Anyone done this themselves and any tips on prepping the rims and what type of spray to use? Going from gold to black and obviously will use original primer so just de-greasing/ smoothing over of original paint I'm guessing??? |
| hursty46 | Oct 27 2012, 11:12 AM Post #2 |
Think it was mongoose on here who did his spokes look in pics his bike us there and good luck with it pal |
| RudiRulez | Oct 27 2012, 11:43 AM Post #3 |
Honestly mate by the time youve bought all the sand paper, primer and paint the cost isn't too much different from just taking them to a powdercoaters. |
| bighit | Oct 27 2012, 12:59 PM Post #4 |
just remember that they are magnesium and they will catch fire if they get too hot |
| chimaira | Oct 27 2012, 01:22 PM Post #5 |
Been quoted £120 for paint shop to do them and dont really have that spare just to change colour of rims so its either make do, or do it meself! ;) as for primer, wouldnt need that part doing as the factory primer would be fine, im pretty sure once degreased its just a case of putting some more layers of paint on... |
| jonny h | Oct 27 2012, 04:23 PM Post #6 |
if your going to do it just make sure you do key in all the corners and stuff as these are the hardest areas to get too. only use water when wet sanding, i know a lot of people used to add washing up liquid etc. i would probably just go in with a 6 or 800 grit. meths or white spirit to clean the wheel after then before spraying use a tack cloth. be prepared to touch up after changing tyres though as they will more than likely chip. |
| rainbowsan | Oct 27 2012, 08:18 PM Post #7 |
Hi av done a few set of wheel myself like you to keep costs down.its all in the prep give them a good rub down then clean i use thinners but i also primer mine but that's up to you build up paint with light coats leaving for 15min between coats when happy. I leave over night then wet & dry clean again then put several coats of clear lacquer had no probs with chipping paint come Tyre change just take your time black being a common colour you can get it cheap try to avoid silicone paint.that you get from cheap outlets as i found it reacts go for it ;) |
| rainbowsan | Oct 27 2012, 08:30 PM Post #8 |
4 X 500 ML SIMONIZ GLOSS BLACK SPRAY PAINT 15.79 with postage 2 X 500 ML SIMONIZ GREY PRIMER SPRAY PAINT 8.79 with postage 2 X 500 ML SIMONIZ CLEAR LACQUER SPRAY PAINT 10.82 with postage thats what I use good coverage hard and durable from sueiain10 on ebay lovely couple to deal with get all my rattle cans from them they will do a better deal on postage should you buy hpoe this helps :D |
| chimaira | Oct 28 2012, 10:48 AM Post #9 |
fantastic, cheers rainbowsan |
| chimaira | Oct 30 2012, 11:00 PM Post #10 |
Well, theyre done!! Its been emotional, pics to follow in the morrow :) |
| hursty46 | Oct 31 2012, 07:55 AM Post #11 |
Look forward to seeing pics 😊 |
| chimaira | Nov 2 2012, 11:40 PM Post #12 |
Say hello to my little friend Before ![]() After
| hursty46 | Nov 3 2012, 12:43 AM Post #13 |
Top job there fella 😃 |
| Monty | Nov 3 2012, 09:17 AM Post #14 |
looking good |
| Ryan90 | Nov 3 2012, 11:00 AM Post #15 |
Looks far far better, well done! |
Yamaha DT 125 - Sold CCM 644 DS - Sold Yamaha R6 - Current | |
2:14 PM Jul 11
