chain tension; adjustment level
Topic Started: Oct 22 2012, 09:26 AM (1,906 Views)
Simon604E
how many inch or mm should there be free play in the chain with no weight on it i know on my bandit its just under an inch with me sat on it but i cant find anything for the ccm cheers guys.
simon.
with bike on sidestand, i allow 2 finger widths up/down movement on top chain run, halfway between sprockets
the set up from the manual is:
rise the bike on a center lift so the rear wheel is hanging free.
measuring the top chain from just behinde the chain slipper guide, it should pull up between 55-65mm
This will seem real slack and rattle like hell if you don't keep your chain lubed,but if you run it tighter it batters your gearbox bearing to death which leads to a total strip down of the engine :o
Simon604E
There is only one thing I like tight and it most certianly isn't a chain ;)
It's tight fitting gloves you dirty set o bastards.
Do you keep them well lubed
whitebuck
Simon604E
Oct 22 2012, 04:31 PM
There is only one thing I like tight and it most certainly isn't a chain ;)
Oh, you're a proctologist then ....... bums away :unsure: :o :blink:
Ride It Like It's Your Ex G/F
Simon604E
Prob not as lubes as it should be but I do try to keep it lubed
