Back on the 644
Topic Started: Oct 17 2012, 03:36 PM (555 Views)
Pa644
Got me a 630 Husky a while back and the CCM landed way at the back of the workshop. Took a while to find out that the Husky´s quite a bit too heavy and won´t go round corners like the 644. And the power/weight ratio got me into a bit of trouble (a couple of bad offs in quick succession on wet surfaces). So put some work into the CCM (gearbox and new cyl. head). Taking it out tomorrow for a longer trial run. Think the Husky´s in for a quiet time and the DS´ll have to get used to the snow again
Aged 644
Glad your still around Patrick, the newish engine did not last as long as the original one then.
CCM's just keep on plodding along
Pa644
Great to hear from you Monty!!
Took it out for a longer ride today. The new engine only needed the gear slipping mended. I was responsible for the loss of power (fooling around with the TPS, coil etc). So decided to do (with a lot of help) the rest. `Tis now better than new. Feels sooo good to be back on the CCM. Much more agile in town, and I missed the snap, crackle etc.
Aged 644
Great to hear the CCM is back in favour Patrick,be good to do a ccmmad rideout to Germany some time and meet up with you guys over there,although I believe db killers would be the order of the day
You did not exactly hang around on the husky Pat, Glad to hear the CCM's back in business.
What happened to the head? burn a valve?
BK350
I can imagine how it is - also was nearly one year without my CCM with her cracked crankcase...hopefully never again.
@Cuz: Have you already started to build a dB-killer for your Scorpion? :D
Cheers Chris
BK350
Oct 18 2012, 03:23 PM
Cheers Chris
Ccm is best sm I've ever rode n I've rode lots 😃
@Chris, I can't bring myself to silence the scorpion :D I'd have to use the other quieter tractor.
