| Indicators; Fuse ? | |
| Tweet Topic Started: Oct 16 2012, 12:06 AM (247 Views) | |
| drinkingparrothead | Oct 16 2012, 12:06 AM Post #1 |
well I lost my indicators tonight messing about with the flasher unit that needs changing cos it's flashing like a strobe light, So I get the handbook out that was originally supplied with the bike thinking it will be a fuse, The drawing shows a flasher unit with 3 connections, I have a flasher unit with 2, and I can't see any fuses on the drawing, And so before I go stripping the bike down to find the fuses I thought somebody on here will know where to look ?. The owners guide/handbook is next to useless, and the drawing that has been supplied in it must be wrong. |
| sullivj | Oct 16 2012, 06:26 AM Post #2 |
I think I saw on the Haynes site, that the 3 prong flasher unit has been replaced with a two prong one, so maybe you have the latter. I have two 10amp fuses on my bike, under the seat. I don't think there are any more, so I would check those first. Check the multi connection behind the headlight as it may have worked loose. |
| Monty | Oct 16 2012, 09:06 AM Post #3 |
The rotax generally has one fuse, usually in the loom near the headstock. the one fuse does all the electrics flashing too fast either means the load is too high, wrong lamps wattage wise or a bad earth and something else is flashing with the indicators to cause this, It may simply be the flasher unit, if 2 wire, loose the earth wire and just connect live in and out |
2:16 PM Jul 11
