| Drying out; Stolen recovered | |
| Tweet Topic Started: Oct 5 2012, 04:17 PM (605 Views) | |
| TigcraftBoy | Oct 5 2012, 04:17 PM Post #1 |
Just heard that the DS has been recovered from the River Wandle Picking it up tomnorrow and will jet wash and then tackle the bits that need to be dried out. Anyone got any experience of recovering a drowned bike and in particular suggestions as to which bits I should prioritise? Thx T/B :unsure: |
| DS644 02 Set up as a SM, Can and jets. | |
| rossonza | Oct 5 2012, 04:56 PM Post #2 |
let everything electrical dry naturally, check clocks arnt full of water. i would empty the tank and carbs/fuel lines and again leave it all to dry naturally. seat sponge may go moldy buddy. but heyyyyyyyyy youve got the bike back! water is better than fire!
| wR1sty | Oct 5 2012, 05:02 PM Post #3 |
Good news mate ;) Im not sure about the problems after a lot of time in water. I would say tank off and flush, headers off, carbs out and clean, oils and filters, plug out and a nice dry place with heating to get the rest dry. Dont be temped to turn her over just in case she hydro locked. It might be worth flushing oil through her too :) Then theres headlight, clocks etc to dry. |
| If your not on the edge, your taking up too much room | |
| stickerz | Oct 5 2012, 05:57 PM Post #4 |
Glad you got it back, i take it it was right in? |
| whitebuck | Oct 5 2012, 06:34 PM Post #5 |
When you've got most of the crap off, take plug out and see if you can find out if the engine stopped on compression, which is usual If this happened then there is almost no water got in the engine from the inlet or exhaust, put the plug back in and take as much off the bike to dry as possible Once the carbs are off you'll see how far the water got, dry out the intake Take the exhaust off and do the same to that then drain the engine oil ...... if you're lucky there will be no water in it In which case only the head really needs to come off The best way to clean everything else is diesel and a tooth brush, the electrics ought to be OK once dry as presumably the ignition wasn't on When it's rebuilt put flushing oil through and then normal oil, it should turn over by hand smoothly Your starter motor will need to be cleaned inside and the windings washed, there should be a local car starter motor place who will do this cheaply Clean and repack your bearings, replace wheel bearings Hopefully the rest will be water stained and clean up OK Good Luck mate, I've been there a couple of times, it takes so long for everything to dry out, I practically totally dismantled the last bike this happened to |
| hursty46 | Oct 6 2012, 10:05 AM Post #6 |
When my fantic 200 got thrown in the canal by my self fell of it I just dropped the oil n cleaned the carbs out n then through a engine flush n petrol flush through it glad you got it back pal did they catch the scum?? Got a handy tool u can borrow if u did lol |
| TigcraftBoy | Oct 7 2012, 08:24 AM Post #7 |
Thanks for your advice guys. Unfortunatley they have a back log of forensic stuff to do and can't pick up bike til Wednesday so the water really will have time to do its stuff T/B |
| mongoose | Oct 7 2012, 09:54 AM Post #8 |
Shitter! Glad you got it back though mate...good times :) |
| bighit | Oct 7 2012, 10:38 AM Post #9 |
if its that bad after the police give it back you may be able to ask the insurer to write it off as it may not be economical to repair it . i know its not a car but by the time you get it back the rust may have set in by that time . it would be a full engine rebuild in my eyes . thats a lot of work for the average joe public . and a hefty bill for labour at a bike shop. i know the bike shops here charge roughly £50 and hour labour if not more . |
| whitebuck | Oct 7 2012, 02:41 PM Post #10 |
^^^ Too right, speak to the insurance company about writing it off with agreed resale to you Call your local big bike dealer and ask them for a quote to strip, clean and rebuild your bike Anthony at Haines would be only keen to chip in on your side if you tell him you'll be needing bits from him Good luck mate, any way I can help, let me know :ph43r: |
| bighit | Oct 7 2012, 02:56 PM Post #11 |
not many insurers will let you buy the bike back . i tried when my 644ds was found . they sold it through theses guys http://www.bluecycle.com/car-salvage-auctions that was aviva i was with |
| hursty46 | Oct 7 2012, 03:57 PM Post #12 |
Rust or no rust chuck a Wurth engine n carb cleaner through it and put some really good make of oil in it n all should be well |
| TigcraftBoy | Oct 15 2012, 09:34 AM Post #13 |
Picked up bike at w/e and there is only slight crash damage and otherwise the bike looked OK. However I was interested that the joy riders had the fuel on and not reserve - why would you dump it before you ran out out of petrol?? Closer investigation showed that post crash they ran out of oil first...........motor locked solid Guess I'll take the money and run as don't have the time or heart for a full nut and bolt rebuild on what will be a total right off Anyone got a ropey DS they want to sell? Prefer S/M wheels as have knobblies still in shed T/B |
| whitebuck | Oct 15 2012, 11:04 AM Post #14 |
Wow mate, that's bad news, even if it does make the decision for you My sympathies :( |
| rossonza | Oct 15 2012, 06:18 PM Post #15 |
that sucks ass!! good luck finding a new bike dude! |
| TigcraftBoy | Oct 23 2012, 08:19 AM Post #16 |
:D Just bought Joe90's DS so back on the road............... TigcraftBoy |
| whitebuck | Oct 23 2012, 09:39 AM Post #17 |
Great news ...... can't keep a good man down
2:15 PM Jul 11
