| Exhaust bolt siezed | |
| Tweet Topic Started: Sep 2 2012, 02:31 PM (561 Views) | |
| ozz770 | Sep 2 2012, 02:31 PM Post #1 |
Transmogrified Teenager
Hi Everyone, I started to clean my exhaust the other day, as its very tarnished & started to rust. So far iv'e polished the box & middle section to a mirror finish its just the front pipe left to do. I managed to get the box & middle section of without any trouble, but one of the manifold bolts is siezed solid, (its the one closest to the frame), its so close that I cant get "Mole grips" etc on it. Iv'e tried to give it loads of heat with the blowtorch, WD40'd it etc, then I rounded the allen bolt with the impact driver !!! Im unsure if welding a nut to it would give me a better grip on it or not, any ideas folks ??? Thanks
| If it aint broke.....Dont fix it !!!!! | |
| hursty46 | Sep 2 2012, 02:35 PM Post #2 |
Welding a nut on might work but when mine went on my drz I run bike till hot then gas axe to get it glowing n it came out with a nut welded on it B) |
| bighit | Sep 2 2012, 05:09 PM Post #3 |
get a torq bit bigger than the allen key hole and belt it into the hole , the smacking of the bit in will help to free the grip of the threads . with the torq bit cutting its splines the bolt should come out . if not as i said it could be head off or engine out heat the ali around the bolt and not the bolt if you weld a nut on you make the bolt brittle . and harden it . if its stainless and hardened it will break and be a complete bitch to drill out ![]() and if you did not know before . i work in engine recons and do this shit almost every day |
| hursty46 | Sep 2 2012, 05:20 PM Post #4 |
Blight could you maybe make barrel bigger?? |
| bighit | Sep 2 2012, 05:48 PM Post #5 |
nope lol we only fix engines not degign or make them. maybe get a barrel bored out and lined but we dont get involved in it . only do liners in tractors or cast iron blocks . there is a place in wolverhampton i have used to get liners fitted to bike barrels http://www.jetbore.co.uk/Cylinder_Resleeving.html they may bore out a std barrel and fit an oversized liner . you would need to find a piston to suit the big end of your rod and the bore of the liner |
| hursty46 | Sep 2 2012, 06:12 PM Post #6 |
Cheers mate looking for a cheaper way to do a 710 kit then laying out 800 notes lol |
| bighit | Sep 2 2012, 06:20 PM Post #7 |
jet bore will do it . i dare say you would have to supply the piston though. omega is the piston people . i have a barrel here that is fubar and would be ideal for an overbore . only thing with liners is if you have a cast iron liner im sure you need chrome piston rings and if you get it nikasil plated it needs cast iron rings . if you just run a cast iron liner a rebore if you size it is easy but if its nikasil plated it would need a weld or two to fill the scores or holes then rebored and replated . me perosanally i would go for a cast iron liner . im sure the piston is about £200 then the price for the overbore then liner |
| hursty46 | Sep 2 2012, 06:28 PM Post #8 |
Cheers chief keep asking my friend who breaks Ccm if he as a 2nd hand 710 kit would like one as its my last mod on bike knowing my luck box would go bang lol if it wasn't for bad luck I'd have none lol |
8:45 AM Jul 11
