| first service | |
| Tweet Topic Started: Jul 18 2012, 07:35 PM (1,339 Views) | |
| rossonza | Jul 18 2012, 07:35 PM Post #1 |
Well I've decided its time to service the r30 Just tipped over 14k miles too. There's 2 filters on Haines for the oil what's the difference? Are there better available? What's the best oil to use? Id like some good quality oil pref under £40 for her. Worth changing plugs? Any fuel filters? Cheers Ross |
| bighit | Jul 18 2012, 07:59 PM Post #2 |
if you can afford to get them go for the brisk plugs. made my bike run better . did not need the choke at all some days where as i had to use the choke all the time with the old style plugs . not sure of the part number . the filters , one will be a genuine one id suspect , suzuki code 16510-37450 , there is a hi flo braned one also . if you google the suzuki number you will find it may fit a few different bikes for example Suzuki factory replacement oil filter 16510-37450 fits S40 Boulevard, DR500, SP500, DR650S/SE, DS650, LS650 Savage, LS650, and more. for oil i used millers oil as i got it cheaper through my work . ZSS 10w40 Engine Oil, Semi Synthetic was the one i bought . i got it for £25 for the 5 litres Description High performance semi-synthetic 4-stroke motorcycle engine oil. Combination of the highest quality performance additives in synthetic and mineral base stocks. Application For engine lubrication of high performance 4-stroke motorcycle, kart and scooter engines specifying a 10w40 viscosity oil. Recommended for the majority of Japanese and European 4 stroke motorcycles. User Benefits Sophisticated performance additive package offers maximum protection and reliability. Suitable for off-road, on-road and track motorbikes. Suitable for use in motorbikes fitted with oil immersed �wet� clutches. |
| CarbonMark | Jul 18 2012, 10:36 PM Post #3 |
I use hein gericke oil in my bikes 25 quid 4 litres and you get an oil filter free!! Its 10 40 semi. Always used it and never had any problems. :D |
Better to Burn out than Fade away!! CCM R30 Carbon meets Cagiva V Raptor. Which 1 shall I ride today??!! | |
| sh4un31 | Jul 19 2012, 07:19 AM Post #4 |
just put halfords semi synt in mine last night . 26 quid for 5 liters (£1 back of quidco as well if u know what that is) done 30 miles so far. all ok when chaging oil. make sure u put some board down. because it dont half squirt out. |
| R30Paul | Jul 19 2012, 09:06 AM Post #5 |
Halfords Semi Syth is fine as the old Suzy donk aint a high revin' kevin... As for the filters HiFlo are also fine... Take it easy undoing the three oil filter cover bolts... Watch out for the spring boinging under a cupboard or round the back of a box in the garage - 'where the fuck has it gone!'... and the filter dropping on the floor with an oil splat, or on ya jeans - 'fuck these were clean on!' - you know what i mean... :huh: when you remove the filter cover... and don't go mad tightening up the 3x oil filter cover screws... When ya re-fill only fill to half way up the site glass (with bike up right) as with spirited riding the engine tends to push a bit of oil back in to the air box if ya fill up any more... |
| jonny h | Jul 19 2012, 01:33 PM Post #6 |
son of a bitch! so thats why i lose a little oil after a fun ride!! |
| rossonza | Jul 19 2012, 01:44 PM Post #7 |
Cheers guys, I've ordered 2 new cr10 plugs and a genuine oil filter from haines and rear wheel bearings too. quick note they said the AJP bearing set on the site is for the spoked wheels. So i ordered the "high quality" 2 bearings for the rear wheel, The guy also stated the front and rear are the same? I may check those other plugs out next service, they didnt have the iridium in stock sadly :S Im still looking at oil options so hopefully i get it sorted soon. day for service is Monday, I hope she likes the new additions |
6:55 PM Jul 11
