side stand
Topic Started: Jul 17 2012, 02:28 PM (557 Views)
sh4un31
trying to get my bike back on the road . repairing the theft damage
for some reason he took the side stand off.
ive just got a used one off ebay
of some one breaking a 604.
the side stand that has come doesnt look like my old one .
mine was straight this one has a 45 degree bend at the end .
cant fit it to my bike unto tomorrow as its at my parents.
question is will it fit or will it need modding or it wont fit at all
thanks shaun
on the 644ds the straight one was the trail stand . the bent one was the supermoto one. the straight one was better in my eyes for the supermoto wheels too as it did not lean the bike too far over as it did with the supermoto bent stand .
if the bent stand fits ,see if you can get a welding guy to cut the bend out and slip in a tube then fit another tube to the bottom then make a new foot for the end .
sh4un31
Jul 17 2012, 04:48 PM
thanks big hit .
i had a theory that one was off trial and one off supermoto.
i actually like it more than the staight stand.
hopefully it fits if not will try and temp bodge it . unto i can get a straight one
i found the supermoto bent one made the bike lean to far . i was convinced that was why it kept snapping the bracket bolts( the bolts were pants. got better ones off steve though) so i used the trail one with both trail and supermoto wheels on. when the bike was stolen it had the sm wheels on and the trail stand .so when i got my newer bike it had the sm stand so i ended up with two sm stands. i got one welded with a bit to lengthen it but ti sticks out too far with the bent end . so i may get the top bit cut off and a straight tube welded on and a new foot
You've got an earlier grey frame one and theres no hassle fitting it. They have a different return spring arrangement If you look at the outside of your swinger near the back of the frame theres a cap screw blocking a hole up. You take this out and put what looks to me like a brake disk bolt with a spacer nut on it and screw that in. Stick yer spring on that and your sorted.
sh4un31
Jul 17 2012, 06:46 PM
thanks cuz. will get it fitted tomorrow .
then no more 3 mile walks to work.
thanks again for your help bighit.
might see how long it is when its on. if i have to make it longer
