R30 rear wheel bearings
Topic Started: Jul 15 2012, 11:11 AM (986 Views)
Just noticed ive got ~1mm play in the rear wheel, There are 2 types on Haines, a 6004 and a 6005,
Do i need 1 of each?
Ross
I'm sure it says on the site how many of each you need, usually you have 2 on the drive side,
http://www.sparesccm.com/images/644DS_RearWheel.jpg
2 x number 13 1 x number 51 so guess 2x 6004 and 1 x 6005
Haines rear wheel kit shows 3 at £15.97
Does hub make any difference?
try a bearing supplier but dont mention its for a vehicle as there is a clause that they cant sell you them as there was a agreement in place at some point . it was between bearing suppliers and the automotive industry .
i got told this by a rep at FAG/INA bearings
The guy from Haines advised the wheel bearings for the MAG wheels are not the same as the Spoked wheels. He advised the Spoked wheels use the AJP bearings.
He didnt say what make the Mag wheel bearings are but advised they were of a high quality.
all ordered and will be changing soon :-)
ill let you know how i got on and let you know the bearing numbers etc.
