new levers ?
Topic Started: Jul 9 2012, 07:52 PM (364 Views)
delstar16
does anybody know any part no.s or what other make of levers are available for a 604 ? im looking for some shorter adjustable levers ! cheers all :bye:
iirc rotax also used domino/brembo brake setup, so anything KTM '99-03 will fit
these have some span adjustment, if you remove the rubber lever bolt cover, you'll see a small knob to turn
on clutch side, just buy new lever and perch assembly that does what you want
hth
delstar16
180920836100 ebay no. do you think these would fit?
brake lever looks correct
dunno about the clutch, maybe see what a ktm400 perch looks like and see?
