604 e rotax oil leak
Topic Started: Jul 1 2012, 05:00 PM (795 Views)
gazkwak
I've got a oil leak coming from the clutch cable where it enters the casing i've tried sealing it with instant gasket, then with a extra o ring but it still leaks has this engine got a breather that could be blocked or has anybody else had this problem thanks gaz
Mikb
About 8yrs ago Mine used to suffer from this problem, I drilled the clutch basket around the periphery, its been fine ever since. I believe This has been done a few times since by others on here too.
I will try and get a pic at the weekend to show how it looks. If I forget as I dont get on here often, send me a PM and my email will give me a nudge.
But I would first check you have not overfilled the oil.
Mick
gazkwak
Thanks will have a look tomorrow the oils halfway up the sight pipe
