Ccm 644 fork oil
Topic Started: Jun 30 2012, 08:15 PM (1,659 Views)
Hi folks I find the front end of my 644 sm very soft any ideas of what to put in it I read somewhere about 15w??? Thanks
i cant remember off the top of my head but dont think about mixing different weights to get what you want for example mixing 10w with 5w and hoping for 15w as it goes the other way .mix 10w with 5w and you get 7w . im sure thats how it works. ( not serviced mtb forks for years ) same oil in mtb forks and our forks on the ccm bikes
found this on another forum
Originally Posted by VStrom650 View Post
Hello,
Question: If you mix 10wt and 2.5wt fork oil of the same brand 50/50 what will be the result?
Add the two weights and divide by two. Also keep in mind that one brand's 10wt may not be the same as anothers, but they should be close.
plus you can tune the forks by using heavier oil or lighter oil than what was in there . its all trial and error really . not sure what the standard oil weight is .
Thanks a lot for info but its confusing :-(( lol can't I just put 15w oil you can buy of the shelf lol cheers
yes you can , thats what i was trying to say , when i worked in the mtb shop people would ask for 15w and if we did not have it they thought they could mix 10w and 5w to get 15w but it works the other way , you would get 7.5w if you mixed them . just trying to save you getting it wrong lol
https://www.google.com/search?client=ubuntu...&oe=utf-8&gl=uk
Thanks a lot dude what oil would u recommend Ive always used silkolene in my bikes or carstrol??
This is next job on bike :-)) how much in each leg does it take?? Thanks again for help n info
never done my forks , never had the bike long enough (one stolen the other blew up lol) at the mtb shop we used rock oil as we were a dealer for them . i think a lot of the mx based oils have more anti foaming additives so the the oil does not froth up when used hard , not sure if that would be the same for a supermoto , you could have a look on the supermoto forum and see what they guys are using. ktm sub forum would be the best bet as its the same forks on the KTM and the ccm
CarbonMark
I have just had my Cagiva done as i thought it was soft. Went from 7.5w to 10w plus a little bit extra. Results are a lot stiffer I dont have adjustable forks tho and would be carefull about trying to stiffen up your forks too much its not a sports bike and having them too stiff could have a adverse effect on the bikes whole handling. Maybe renewing like for like could be the best option and then get it setup for you which is what i had done on my old r30 and it made a real difference.
Better to Burn out than Fade away!!
CCM R30 Carbon meets Cagiva V Raptor. Which 1 shall I ride today??!!
Hi mark ye get what your saying but they way to much sag in them I can adjust my rideing to the bike set up I do when I jump from sm to sports bikes to track bike n trials bike lol thanks for info I'll keep ya posted when I have changed it :-))
CarbonMark
Mate mine had very little sag once it was setup for me. My mate did for me he's a mech/racer. Took him all of 2 minutes and cost me a packet of buscuits!! Best pound I have ever spent on a bike!! :D
Nice1 will have to get it set up correctly by a expert lol.. Cheers for info...
