604 fork seals pioli
Topic Started: Jun 26 2012, 09:11 AM (440 Views)
watts
Anyone know how to change these I want to try. It . And what weight oil should I use for rail riding :dirtbike:
Posted ImagePosted Image
watts
they are not piaoli they are marzocci 50mm. and for the last 2 years i had a local bike shop mot my bike because of work and having no time. each time it comes back he had changed the wheel bearings blanked out the lights because i have a daylight mot, brake pads and that what about it. the bill was alway around the £250 mark . oh and he always changed the fork seals i nknow this because everytime i took it in the were leaking and he would always mention it at the end. i never thought the price excesive but it dawned on me that i hardly use the bike at all really and twice the seals had gone so i ordered them and stripped it down to find tissue paper stuffed in the top. or did i make a mistake and is £250 the right price for a daylight mot with bearings , pads and a bit of a fiddle with the lights.
[url=[IMG]http://i716.photobucket.com/albums/ww165/wattsatllan/IMAG0447.jpg[/IMG]]My Webpage[/URL]
watts
the forks on my bike are marzocci magnum 50
Tech Info
Magnum FAQ
How to identify model years?
93-94 Magnum 45: Has alloy damping adjusters
95-97 Magnum 50: Has blue plastic adjusters
98- Magnum 45 & 50: Has slot-headed adjusters
Oil Levels, all use SAE 7.5w
93-94 Magnum 45: 190mm
95-97 Magnum 50: 135mm
98- Magnum 45 & 50: 140mm
Oil Seals
Magnum 45, 93-97, size 45 x 58 x 8.5/11, part no. 528145
Magnum 45, 98<, size 45 x 58 x 11, part no. 528197
Magnum 50, size 50 x 63 x 11, part no. 528203
Thats great info Watts for you boys with the early tractors
p.s. I think your being ripped off mate,especially with the bog roll oil seals,do it yourself if you have time and space,most things can be talked through on here
watts
yeah i done them now mate . i been dealing with ray cowles motorcycles in pontypool for years but this is an eye opener , bit gutted really
RudiRulez
Yeh looks like you've been done, no way would I go there again unless its to chuck a brick through the window.
Looks like he's charging for oil seals but instead of changing them he's just packing it out with loo roll to soak up the leaks for a while.
