Exhaust back box; Re-packing.
Topic Started: Jun 14 2012, 07:44 PM (260 Views)
Thumper644
I saw a thread about re-packing the exhaust back box.
Mine is very noisey with the baffle in. It sounds hollow when you tap it.
Its a standard one, that has no rivets holding the ends on.
Do they press in ? Can you prise the ends off ?
Is the standard box non service-able ? (or not worth the effort)
Has anyone stripped one down?
R30 & RD250D, grunt or scream?
if its the remus one look in the end . there is a small pipe welded in there , that is the outlet hole , the insides are just like a maze of pipes that are the baffles . you need to grind the weld out and the insides will come out. it will weigh a whole lot less also . you can then get perfforated tube and paccking wool and make the standard can into a race can but it will be a straight thru can and mega loud .
i have one that i cut open at work just now . you will have a tube ( the outer can) and two end caps .
cutting it open is the only way to repack it. marc on here had pics of one cut open
