| 604 cut out and wont start again :( Help | |
| Tweet Topic Started: May 28 2012, 08:10 AM (650 Views) | |
| Jimmyb | May 28 2012, 08:10 AM Post #1 |
Hi guys im hoping you lot can help, I was on my way to the BSB at snetterton on sunday And my bike just cut out, the were no bangs or metallic Sounds. Rolled into the layby, tried starting and nothing It sounds like the starter is has no load on it. So tried the kickstart and it felt light and made a ticking sounds Also if i put it in gear i could move the bike with the clutch out Any ideas?? Thankyou |
| too old | May 28 2012, 10:57 AM Post #2 |
Hi Jimmyb Maybe there is no compression
| Jimmyb | May 28 2012, 11:11 AM Post #3 |
Hello mate, yea i dont think there is hardly any compression, a friend of mine thinks one of the valves has closed up... Is that expensive lol? |
| too old | May 28 2012, 01:06 PM Post #4 |
Hi Jimmyb Take the head off and all will be revealed Expensive it could be , how long is a piece of string
| Monty | May 28 2012, 02:35 PM Post #5 |
Do a wet and dry compression test first. remove plug and fit compressor, spin over note pressure. Squirt a few cc's of oil down the plug hole and test again if no change to readings then valves are letting by, if on second test compression is up then rings are letting by. head will come of in the frame, you may have to remove starter motor and front mounting bolts so engine will tilt forward, also remove tappet covers, new O rings in for sale section. |
| Jimmyb | May 28 2012, 04:07 PM Post #6 |
Thanks for your advice guys, just picked the bike up and done Abit of investigation, the cam belt snapped which i had replaced 2000 miles ago So im guessing at the least a bent valve :( Has anyone had any experiances like this if so what was the damage? Oh i put the old belt on and no joy so ive got the cam which Smashed it all lol |
| Jimmyb | May 28 2012, 04:10 PM Post #7 |
**an old belt lol |
| cuz62 | May 28 2012, 04:53 PM Post #8 |
i cant say what damage you have done,but the head removal is very easy,i did mine last week,i had to remove the starter, front engine mount bolt,carb and top rear engine mount/ Stabilizer,and cam covers then tilted the engine forward and removed the head,obviously you have to remove the cambelt cover but you have already done that,i bought my new o-rings off monty |
| Jimmyb | May 28 2012, 06:51 PM Post #9 |
Right guys, ive started to strip the engine down to get the head off but i Need a puller to get the top cam wheel off, is there anyone Round the suffolk area that can lend me one please? Ive had the valve covers off and it all looks ok in there :D |
| cuz62 | May 29 2012, 07:44 AM Post #10 |
try putting two screwdrivers or small tyre levers at opposite sides and lever it off,theres also a threaded hole you can screw a bolt into,mine came off with the levers |
| Jimmyb | May 29 2012, 09:07 AM Post #11 |
Ok cheers bud, will give it a try |
| Jimmyb | May 30 2012, 05:42 PM Post #12 |
The exhaust valves are bentso need replacing. the piston looks ok apart from two little marks. Will this affect the running of the bike? |
| Monty | May 30 2012, 07:01 PM Post #13 |
The bent valves wont help :D Sorry, the marks on the piston will be fine, lucky they did not go through, shame cos they are the expensive ones, inlets are cheaper |
| Cuz | Jun 3 2012, 11:31 AM Post #14 |
Make sure you get the tension right on the belt when you refit and check the upper cambelt wheel for wear as this is what causes the belt to snap. |
8:47 AM Jul 11
