Fuel Starvation??or something else??
Topic Started: May 27 2012, 06:35 PM (535 Views)
neaty5000
Hi Guys
Having a problem with my 644 DS, its holding back at higher revs intermittently - to me its like once ive accelerated hard once or twice and then i go for it again it holds back about 2/3rds of the rev range - as if fuel starved. its then ok again if i bimble - possibly float height is incorrect? and im using the fuel up before it has chance to be refed?
Its done 4700 miles
I have just checked TPS and adjusted - wasnt far off so no change
K&N fitted - air box lid removed
Sports exhaust
150 main jet
25 pilot
Needle on second clip
New fuel
Cleaned out fuel filter - original type inside fuel hose
new plugs
Emissions items removed and blanked
Any ideas??
You may have to drain the tank, there has been issues with the swarf from the drilling of the fuel taps blocking the filters(which you have checked) may be large particles blocking the internal pipe
Shot in the dark, but you will changing the pilots I know.
Tesco's fuel or shell, basicly what I mean is crap from supermarket pumps or the better stuff from a larger company
98 octane if your wallet will go for it, will run ok on 95
neaty5000
Ok, ive just checked the fuel tap and tank breather - both are clear of blockages
Fuel filter is spotless
Tank was drained a couple of days ago as the filter had dirt in it
Changed Main jets and cleaned out float bowls too
so ruleing out those items
It is on supermarket fuel 95 ron - but why intermittently?
found an old thread on ccm riders with owners having the same problem but no resolve - talk of high flow fuel taps etc
I am changing the pilot jets soon, so i thought it would be a good time to check float heights
Cant find any guides to do this though?
Marc
I would check the diaphragms atop the carbs,they could be ripped/nipped and make sure clips are both set in the same slots while you are at it...
Edit : 2nd slot seems low from my feeble memory,are we talking from the top or bottom,I'd
be tempted to aim more to the middle range
neaty5000
............ Continued
Removed Carbs tonight
Diaphrams are perfect
Needle setting second from bottom on both
Changed pilot jets and bowl screws
Added Redex fuel cleaner to fuel
Set mixture screw
Took it for a ride - was better but it didnt seem to pull that strong, so i replaced the airbox lid and it was much better!
Do i need a bigger main jet than 150?
Tops out at 95mph on trail wheels is this normal with standard gearing?
pickle3
I would of said bigger pilots too, I got twin air dualphase foam and I got 27.5 pilots and 150 mains arbox lid off. Not sure if for 710 with box removed completely but remember off riders with k &n with 157.5 and 162.5.
Or get some more 150 and drill them out till you get desired performance
:dirtbike:
http://i864.photobucket.com/albums/ab205/p...13/SAM_0759.jpg
150's should be fine with lid off, if it runs better with lid on, is it low down or throttle wide open, pilots usually work from fully closed to about 1/3 throttle mains approx 1/2 to full.
You may have a leak in the inlet manifold, hense having to refit lid
95 on trail wheels, scary, why? private road of course
neaty5000
Forgot to say that i had checked float setting using clear tube method -
Both carbs where level with the top of the float bowl joint flange.
Intake leak wise - the only thing i can see could make a slight difference is the aluminium pipe that fits between the manifold and air filter is not bonded into the rubber manifold - not sure if they are supposed to be?
But it is a snug fit, so?
What would be a good solvent to bond these?
The private road test was me trying to establish if my bike is down on top end power
The ring for the airfilter will not be an issue, its the rubbers fitted to the head that could cause your problem
Try spraying carb cleaner at strategic points when the bike is running. The revs will rise if theres an air leak at that point as carb cleaner is drawn in.
I have attached a diagram that will will explain what jets do what
neaty5000
Thanks Monty
Thats a great diagram and a handy tip with the carb cleaner i will give it a try
pickle3
Silicone sealent. <..spelling
Don't think that is std though just what I used.
