| R30 rear number plate guard | |
| Tweet Topic Started: May 21 2012, 02:05 PM (566 Views) | |
| Trev16 | May 21 2012, 02:05 PM Post #1 |
Hi everyone, The rear plastic number plate / mudguard / bracket where the indicators bolt to ( whatever its called) on my R30 has cracked down both sides below the indicators..The bracket seems easy to get hold of but iam led to believe that the captive nuts inside the tail piece where the bottom allen bolts screw into more often turn when the bolts are undone ..Anyone had any experience of this or any solutions/ideas?....Can you get to the nuts from under the seat? Thanks Trev. |
| jonny h | May 21 2012, 04:38 PM Post #2 |
never had a problem with those, im pretty sure they are secure within the casting of the tail piece ... are you sure they wasnt talking about the nuts holding the seat on? those little blighters have been known to turn frequently. |
| Trev16 | May 21 2012, 06:28 PM Post #3 |
Hi ,It was Haines who told me about it and iam sure it was the bracket nuts but i will have to take my chances i think...Bye the way how does the seat come off!? |
| CarbonMark | May 21 2012, 06:33 PM Post #4 |
Mine did the same so i cut it off where it cracked and then got some thin brackets from Halfords and fitted them using the bolts under the seat and bent them into shape. :D |
Better to Burn out than Fade away!! CCM R30 Carbon meets Cagiva V Raptor. Which 1 shall I ride today??!! | |
| Trev16 | May 21 2012, 06:57 PM Post #5 |
Thanks for the advice....What brackets did you buy and i take it the bolts under the seat came undone ok? |
| CarbonMark | May 21 2012, 09:11 PM Post #6 |
In car entertainment brackets only a couple of quid. Can't remember which bolts i used but they came off fine. I will look in the morning and let you know which bolts i used. |
| jonny h | May 21 2012, 10:58 PM Post #7 |
un-do the two bolts either side near the back of the seat, pull the seat backwards. you might need to push down on the front a bit as the guide can be a little tight. |
| Marc | May 24 2012, 05:35 PM Post #8 |
Be aware the captive nuts in the seat can ,at least they have on 2 different seats I've had... |
| Trev16 | May 25 2012, 05:40 AM Post #9 |
How did you get round that if the nuts on the seat turned? |
| bighit | May 25 2012, 04:36 PM Post #10 |
once you do get the seat off , get some T nuts and fit them where the original ones are . they will need to be drawn in by a bolt or pressed in . i used them on my old seat
| jonny h | May 25 2012, 05:29 PM Post #11 |
you need to drill the bolts out, this is pretty easy with normal alloy bolts, a apin in the arse if you have stainless steel though <_< |
| bighit | May 25 2012, 07:11 PM Post #12 |
you could try and use a drill bigger than the threads and drill the top off the bolt. but i guess you would then have to try and turn the threaded part with out the captive nut spinning |
8:47 AM Jul 11
