valve clearance 604 rotax
Topic Started: Apr 16 2012, 01:49 PM (716 Views)
watts
As above , thanks in advance
Posted ImagePosted Image
i think its 4 thou in 6 thou exhaust but i ma be wrong . its something like 3 to 5 inlet and 5 to 7 exhaust. i may be totally wrong . monty or cuz will know for sure
I set them up as Paul says 4 thou inlet 6 thou exhaust, tho the manual does say 0.05mm.
now thats confused ya, thou and mm
When I do them for others I use 4&6 thou
You decide :D
4 thou is the lowest we go at work for anything . under that is less than the thickness of a newspaper page . ( newspapers are around 3 thou ). the thing with a 4 stroke is when it goes quiet tappet wise then you should worry as it will be too tight and burn the valve and seat if the valves open a fraction as its forced through a narrow gap rather than i wide gap .
also if a valve opens more than a quarter of its diameter you wont get any more gains from it
Apr 16 2012, 07:48 PM
You decide :D
it is confusing . the autodata books tell you in mm and we set them in thou. we skim heads by the thou . we measure big ends and mains in inches and mm . i get confused every day lol
I've always set my 865 cam tappets at 4/6 thou and my 860 at 6/8. Maybe rotax quote 0.05 for some plodding cam. Was talking to Arge the other day about knackered cam wheels on the rockers and he pointed the finger straight at badly set tappets...be warned!!
Dirty_Rotax
Always nice to hear a quiet clicking sound, You then know they aint too tight.
Rather a tad loose than tight I say, for tappits that is :D
Vicky Verky for Saturday night fun ;)
Spanking the Monkey, Oh Yeah.........
