| size of the holes in the airbox lid? | |
| Tweet Topic Started: Apr 6 2012, 09:30 AM (474 Views) | |
| yoshimura | Apr 6 2012, 09:30 AM Post #1 |
Hi, i bought a ccm r30 and at the bike was no airbox lid/top-plate, because the seller of the bike lost it in his garage..... . It was not ready to drive with this jetting (main jets 115, twinair filter). I made a plate by my self and changed the main jets up to 135. But with the new kn filter it feels the gas/air mix is to poor. i think the holes with 35mm are to big, can tell my someone whats the original size of the holes? cheers Joe ![]() |
| Tricky | Apr 6 2012, 09:52 AM Post #2 |
If you have a race can fitted then 25mm holes should do it. i lost mine and had to make a dummy one, i put four holes in it and it runs well right through the rev range. It's a little twitchy on tick over but thats about it. Probably running a little rich but better to run rich than too lean. Edit: Just noticed your perpex jobby. Looks better than mine - i just used a piece of cardboard wrapped in insulation tape. :lol: |
| yoshimura | Apr 6 2012, 10:19 AM Post #3 |
Hi, thanks for the reply. so my holes are much to big and i try to close two of them with isulationtape :D regards joe |
| Monty | Apr 6 2012, 11:19 AM Post #4 |
Original lid has 6 holes, these were opened up to 25mm and worked well will 135 mains and std pilots, plus race can. area of 25mm hole is 4.9cm X 6 holes = 29.4cm area of 35mm hole is 9.62cm X4 holes = 38.48cm So guess to get correct air flow only block of one hole not 2. |
| yoshimura | Apr 6 2012, 12:22 PM Post #5 |
Oh thanks, i forget there was 6 holes at standard. |
| Marc | Apr 8 2012, 01:11 PM Post #6 |
Or just get rid of the airbox completely if you like... |
8:45 AM Jul 11
