| tps adjustment | |
| Tweet Topic Started: Mar 29 2012, 05:22 PM (3,356 Views) | |
| Monty | Mar 29 2012, 05:22 PM Post #1 |
Written by Monty (some time well in the past) TPS Adjustment (Missfire and Under Powered?) If you think things are not right, before taking your carburettors apart check the Throttle Position Sensor, I always thought mine was ok as factory set and never gave it a thought, all you need is a multimeter, basic instructions are here. There are 3 pins in the unit; measure the resistance in k ohms across the 2 outside pins, a reading of between 3 to 6 k ohms should be seen. Make a note of what it says, get a calculator and work out what 76% of that figure is. i.e., outside pin resistance 5.23 k ohms ----76% of =3.97(these are my figures, swap them for your own) Hold the throttle fully open and measure between the top and middle pin, the reading should be 3.97(your figure), if it is not slacken the 2 screws and move till the figure is the same as what you worked out. Your ignition timing should now be correct; you may have to remove the tank to access the pins better. From the 4 sets of carbs I've seen, the TPS has always been mounted in the centre of the slots, which for quickness sake means they will all run but may possibly not be exact. |
| Rob 110 | Oct 22 2012, 04:47 PM Post #2 |
this thread is nothing without pics:D http://www.4shared.com/photo/98j1g0RW/Cable_Tie.html http://www.4shared.com/photo/R2NvK_dO/Before.html http://www.4shared.com/photo/A6RzI8K3/Start.html http://www.4shared.com/photo/bpPL6_NT/After.html |
| whitebuck | Oct 28 2012, 11:03 AM Post #3 |
Thanks for the link Rob ;) |
| ac@39 | Apr 19 2013, 04:31 PM Post #4 |
not really understanding what all this means but have measured mine start 05.1 75% is 3.825 and i have 3.9 me thinks near enough but dont know what effect the 0.075 equates too ... anyone know?? Edited by ac@39, Apr 19 2013, 04:31 PM.
small willy..huge ego...and no brain cells...
| Monty | Apr 19 2013, 04:36 PM Post #5 |
That will be fine, Although its 76% not 75% Edited by Monty, Apr 19 2013, 04:36 PM.
| ac@39 | Apr 19 2013, 04:45 PM Post #6 |
with correct figure of 76% its even closer at 3.876 all good in that department so i is happy.. cheers monty |
| 4l0 | May 20 2014, 01:25 PM Post #7 |
Nice right up Monty mines was 5.39 ...............76% of related to 4.10. Sensor was set half way,surprised how much i had to move it to get it bang on. |
| Running 150 mains 27.5 pilot jets, K&N, needles 2nd from bottom, TPS set, valve dingy junked, Irridium plugs, Remus race can.............................need a Kent cam next!!!! | |
| Winder | Jul 14 2014, 02:36 PM Post #8 |
When you say slacken the screws and adjust until correct what exactly am i adjusting? The depth the screew is in or out? The angle of the TPS unit? Im about to get the multi meter out and do it now Never mind, worked it out. Didn't notice the pivot when i looked in the dark last night. Got it spot on now. Still runs like crap with that beowolf exhaust on it. I opened up the can to repack it and it was completely empty!!! It now sound spot on with the baffle in now i have repacked it. Edited by Winder, Jul 14 2014, 03:11 PM.
| Walshy | Jul 14 2014, 03:49 PM Post #9 |
Nice one |
| leomn | Apr 27 2018, 07:27 AM Post #10 |
| Rob 110 | Apr 27 2018, 11:15 AM Post #11 |
Flipping image hosting gggrrrr It is in the 'Files' section if you look at the top and follow it to: https://www.dropbox.com/sh/jil77ygks7bkn7r/AAD72z4XO8Jo50upFJMe-9k-a/CCM/644?dl=0&preview=TPS+Adjustment.pdf https://www.dropbox.com/sh/jil77ygks7bkn7r/AAD72z4XO8Jo50upFJMe-9k-a/CCM/644?dl=0&preview=tps+adjustment.doc |
| leomn | Apr 27 2018, 12:49 PM Post #12 |
Thanks, very efficient. Presumably the first reading is not affected by adjustment? |
| Monty | Apr 28 2018, 08:53 AM Post #13 |
You are correct, the first reading is the whole resistance of the resistor, should be around 5-6k ohms |
| leomn | Apr 30 2018, 07:54 AM Post #14 |
good 'ere innit
2:45 PM Jul 11
