Carb balance / sync; how to
Topic Started: Mar 28 2012, 09:21 PM (675 Views)
andaroo
Hi, new to site - have a 644 R30 & it is a bit 'fluffy' at low revs - fine higher up the rev range & was wondering if the carbs need syncing?
Thanks.
lazybones51
The Legend
Whats your setup ? Exhaust, Air filter, carb jets and needle position ? Have you removed the vaccum gubbins ?
Kev.
CCM 644 DS - Yellow - Owned for five years, now gone :-(
Fiat Cinquecento SX - Green
Fiat Cinquecento Sporting - Yellow
Follow my adventures - http://blog.kevinmace.co.uk
andaroo
Hi, it's an absolutely standard 2002 model
andaroo
Should add it's only done 6,700 & nothing has been interfered with.
To get the best from your bike
1/ remove the valve lift gubbins from the carbs
http://www.4shared.com/office/AFtE9jwo/Thr...e_Lift_Con.html
2/ check and set up the TPS on the carbs
http://www.4shared.com/office/87u9m2ns/TPS_Adjustment.html
read the write up in the how section, explains the pics better
3/ fit 150 main jets and 27.5 pilot jets, try the needle on the second from bottom clip, remove air box lid, fit race can or road legal can, ie quill evo 2
all in 3/ need to be done at same time, also make a cage for the foam filter as they collapse at high revs or spend more money on a K&N RC2600 (£40ish)
It will then go a lot better.
