Clutch slippage; Help!
Topic Started: Mar 19 2012, 07:08 PM (1,273 Views)
BenB404
i dont think should go in the chat/tech section because its not a CCM.
Theres very little slack at the end of the clutch lever and the biting point is really really far out.
When Im riding through all gears (well what ive managed to use) I open up the throttle it revs freely but doesnt really go anywhere. Then all of a sudden the revs will drop and it will pull like a train. It did this after a 20 minute ride consistently so im guessing it can be because it cold.
Could be:
the clutch cable is too tight,
fully synthetic oil,
the clutch is fecked.
if its the clutch, what do I need... Clutch plates, clutch kit, etc... theres such a mix to buy from:
Ebay link
Current Bike; KTM 520exc 2001. Carb rejetted and EMN needle.
Previous CCM; CCM 404DS Supermoto 2004. Several Carb mods, Jetting, Taffy Mod, EMM needle, Coast Enrichener removed. R30 Straight through exhaust, custom headlight.
Previous Bikes; Yamaha FZR600 1991. Yamaha DT125Re 2004.
Oh Yeah... I have a Capri!
I'd do an oil change first, and put in semi.
Did the same on my Tigger many years ago, filled up with fully syn and slipped when given the beans, changed back to semi and problem gone
Failing that if it does not work change the friction plates,(I would fit EBC) but give the drive(metal) ones a check over at the same time
BenB404
Cheers Monty. Very fast reply.
Guess what I bought yesterday ready for a service...
Fully Synth :blink:
Everywhere suggests fully or part, so I wouldnt have thought it would make a difference... But its always worth a shot :D
i got 15/50 fully synth for the 644 .cost me nearly £50 :o and me being me i opened it to see what 50 quid oil looked like then found out it was no good to me so could not take it back :rant:
BenB404
Bollox... I opened it yesterday!!!
Thats £26 gone... Someone might buy it off me!
clutch went slippy on my old translap on a trip at around 25k miles
i laid the bike on its side, removed clutch cover and preloaded each of the four springs with a couple of M8 washers
did another 20k miles before selling the bike B)
BenB404
@Rob, as clever as that sounds... I've never worked on a clutch :D
But im guessing; does that pull the clutch further away?
nope makes tired springs push harder
but only ok if the plates aren't worn out
BenB404
Passed MOT :D
Then the clutch went on the way home... there was no power at all... cable was all floppy, and it stayed running at a stand still in gear... and it can be pushed in gear and feels like neutral:
And heres the one end of the cable... it couldnt be anything else could it?
i dont think I was ever meant to have a sportsbike lol
kermit
did we find out what this was? sounds like what i have at the moment with my 644!!!
Why spend £50 notes on oil when you can buy 5l from Halfords for £25.99 lol always use there oil in the Ccm
i used halfords oil in my 644 and now use it in the yam, works perfect. no slippages for me
I've not tried it in my Tls yet but will do on next service lol
