| 644 swingarm bearings, another way | |
| Tweet Topic Started: Mar 15 2012, 08:29 PM (7,061 Views) | |
| Rob 110 | Mar 11 2015, 08:37 PM Post #41 |
oh cock the LME16UU Closed Linear Ball Bushing with Rubber Seals 16x26x36mm won't fit cos its 16mm internal diameter the internal diameter needs to be 20mm. Top Hat OD = 20mm Spindle OD = 16mm if you run the 16mm spindle in the LME16UU you are changing the design and removing the top hat as pivot |
| Tramp | Mar 11 2015, 09:03 PM Post #42 |
Yep..found that out.. Ive bush waked the bush in swing arm and it fits nicely..with just pivot bar its smooth and snug... Is there any reason we cant that way and loose the top hat as its running on rollers in bush ..ill use plenty grease... ROB ? What does you think... |
| Rob 110 | Mar 11 2015, 10:03 PM Post #43 |
spoke to engineers at work about this when i originally was trying to improve it they said it was changing the design and altering stresses/bearing surfaces and engineering words i didn't understand :D |
| Tramp | Mar 12 2015, 06:57 PM Post #44 |
Ahh !! What do engineers know..lol Im going to push my head above the trenches and try it anyway... Always have the oilites and top hats to fall back on... Just waiting for replacwment. Spindle then its put humpty back together again.. |
| gmanb1h | Mar 18 2015, 11:18 PM Post #45 |
Ordered oillite bushes. £15.55 delivered from simplybearings. Hope I don't need bushes for a while. Thanks for the upgrade information as the needle bearings aren't the best idea for this bike. Edited by gmanb1h, Mar 19 2015, 07:48 AM.
| Tramp | Jun 30 2015, 03:26 PM Post #46 |
Update..had rear wheel out for new tyre and rear swing arm has loads of play so going to investigate further... Worth a try eh..will let folks know the outcome...only done 1k ... |
| Rob 110 | Jun 30 2015, 07:28 PM Post #47 |
oh dear, can't remember if you did Oilites or not? mines still fine on the original set, but thats the R30 on the road mostly and some light trails |
| Tramp | Jun 30 2015, 08:03 PM Post #48 |
Non olites...the ones without the top hat and roller bearings in seals..ill take some.pics for folks when i rip it apart tomoz...got some new olites down the man cave so no big deal...something to do in the sun lol.. |
| Tramp | Jul 1 2015, 02:34 PM Post #49 |
okay..sweated my ass off in the sun and the old linnear closed sealed bearings where showing play but the seals where still good...anyway think the reason they went so quickly was lots of freeplay along the shaft..I must not of had the nuts done up tight enough so the swing arm moved left to right along shaft..increasing wear.. I used the bushwaker tool and removed and replaced with new olites and top hats..zero movement now along the shaft as Ive welded the nut on one side ...see how long these last... shame another swing arm couldnt be used so a better bearing/seal as its a real pain and weak point on a great bike..Honda would be a good choice. |
| Mike Wright | Nov 1 2015, 05:42 PM Post #50 |
Just wondered how people are get on with the bushes replacement? How are they going as I am thinking of using them on the 404DS for for green laning? I presume the swinging arms are the same so need to order the same sizes? Thank you |
| Tramp | Nov 1 2015, 06:17 PM Post #51 |
The olite bushes are okay but wear fast when green laning due to muck and suspension travel...on the road im getting better mileage from.them.. Next time im going to get a 2nd hand swing arm and try and modify it to use better roller bearings and proper seals... Ill.update as and when but it wont be soon lol...also use the grease nipple on mine better thannit does at moment...i wont be beaten. |
| Rob 110 | Nov 1 2015, 10:10 PM Post #52 |
As Tramp says R30 ones have been in mine for 10,000miles ish Different size on 404. Search as there was a thread on it I'd get 6months racing/green laneing on mine |
| Mike Wright | Nov 2 2015, 06:57 AM Post #53 |
Thanks Rob.... the standard ones have lasted quite well on mine so I was lucky although there quite expensive to replace if you factor in bushes as well arent they OEM. |
| mspenz | Feb 2 2016, 09:00 PM Post #54 |
Nylatron GSM looks interesting but it would have to be bought as a blank and machined to the right size! |
| 06' 644. 150 main jet, 27.5 pilots, needle @ 2nd rich, air screws @ 3 turns out, K&N with airbox lid....on and unknown unrestricted end can. Now goes like sh1t ! | |
2:45 PM Jul 11
