| Half throttle stumbling | |
| Tweet Topic Started: Aug 13 2016, 06:51 PM (267 Views) | |
| Jeravoy | Aug 13 2016, 06:51 PM Post #1 |
Need some help please .my 604 is good to run up to half throttle and then it stumbles bad and then I ride through it and it then goes like stink.what can I do .it's just at 50-60 mph |
| markslashbill | Aug 18 2016, 07:01 AM Post #2 |
First off, check it over. Check the inlet rubber manifold especially for cracks. If you spray some sort of solvent on the inlet rubber while it is running there should be no effect on the motor idle speed or there is a leak. Take it off and look at all the jets and give them a clean out. |
| R30 604, GL1100, XT600, C90 | |
| Monty | Aug 18 2016, 07:31 PM Post #3 |
Plus the most important thing is the float height, 17mm, if its out it will cause all sorts of probs |
