Carb leaking fuel ,Oil change?
Topic Started: Jun 24 2016, 06:26 PM (724 Views)
tommysdad
I've just got round to replacing sprag and new oil seals ,all good so far . poured the first 2L of oil in .Put thee tank on turned on fuel and petrol pissed out from the overflow on the carb pipes and bottom overflow. pulled the carb and give it a clean will check float height , float valve looks ok . Should I change the oil , quite a bit of fuel leaked out. bike has been stood for a while before this happened.
Thanks
I'm a man with a fork in a world of soup
Ant P
Sounds like your float needle is sticking or float height needs setting. Pull the carb off and check. These Dellortos idle badly as well if youve got float needle sticking/ float height incorrect
tommysdad
Ant P
Jun 24 2016, 06:40 PM
Looking at that now thanks Ant, just wondered if the fuel could have leaked into the engine.
Dom-r30
Take the filler plug out and give it a sniff?
My oil stunk of fuel when I was having trouble with float valve passing.
