| brake hoses; Probably a stupid Question | |
| Tweet Topic Started: May 4 2016, 09:04 PM (388 Views) | |
| 604ja | May 4 2016, 09:04 PM Post #1 |
Hi Guys, I've been looking into getting new braided brake hoses, something like HEL or Goodridge but they don't seem to list my model a 604e sm . I'm assuming the 644 will have a different rear hose as the caliper will be on the jap side. I'm sorry but I am still very new to the world of CCM . Did the R30 at first come out with a Rotax and if so does it use the same lines . |
| Monty | May 5 2016, 06:18 AM Post #2 |
You may find they are the same as a KTM, as the CCM uses the same forks & calipers, which model I dont know |
| Rob 110 | May 5 2016, 08:00 AM Post #3 |
venhill do an excellent service, http://www.venhill.co.uk/Hoses_&_Cables_-_Motorcycle/CCM-ARMSTRONG/500-644/604/604_E-DS_00-02 i had some one offs made for a rally bike too by ordering online, you just select length/fittings etc http://www.venhill.co.uk/Hoses_-_Components_&_Lines Edited by Rob 110, May 5 2016, 08:02 AM.
| 604ja | May 5 2016, 07:14 PM Post #4 |
Nice one Guys thanks for the info . Bike wont be going anywhere for a while . I got home from work to discover the top cam belt cover is missing . Going to cycle to work tomorrow and see if I can find it. Fingers crossed because it looks like they are rarer than rocking horse doo daa. |
| jonny h | May 6 2016, 11:31 PM Post #5 |
if you are running the WP forks this will give you your front brake hose - http://www.venhill.co.uk/Hoses_&_Cables_-_Motorcycle/HUSABERG/500_-_600/FE_550_e/FE_550e_2004-08/K01-1-028-P_KTM-HUSABERG_FRONT_BRAKE_HOSE.html if you have the blue Paioli's they are slightly longer and will need to be made up with you providing the measurements required. i rate the Venhill stuff over Hel etc, as for your cam belt cover, maybe try Gary at Sportax if you havent found it, he might have one. he also sells the gaskets for it too ... and anything else Rotax |
8:55 AM Jul 11
