| Urgent....644ds oil cooler | |
| Tweet Topic Started: Apr 10 2016, 01:48 PM (302 Views) | |
| Tramp | Apr 10 2016, 01:48 PM Post #1 |
As it says my oil cooler has sprung a leak in cooler, so need a replacement asap as in 10 days im off to france...just rode 170mls and found out....so pisssed off... |
| Monty | Apr 10 2016, 03:30 PM Post #2 |
I'll have a look, think the only one I have is slightly bent, but dont leak |
| R30Paul | Apr 10 2016, 08:46 PM Post #3 |
Worst case untill you get a replacement sorted or yours brazed - remove the cooler and link the pipes... or link at the in and out.. Someone on the old site used to run a 644 without an oil cooler - i think he lived in cooler climate, but should be ok untill summer hits |
| Monty | Apr 10 2016, 08:59 PM Post #4 |
Found it, outside frame bent in a bit, and put a slight bend in the first cooling bar. I'm sure when fitted it did not leak, I just chamged it for a straight one |
| Tramp | Apr 11 2016, 05:19 AM Post #5 |
Cheers Monty... Ive ordered the one off ebay but if its no good ill contact you ....thanks for looking. |
| « Previous Topic · Wanted · Next Topic » |
8:37 AM Jul 11
