Power peaking??
Topic Started: Mar 31 2016, 08:58 PM (1,315 Views)
Ant P
Cool thanks, i,ll look into one. Meanwhile i may as well check for bad earths etc
Ant P
Checked for earths? Does the rec body need to be earthed? I moved the rec under the seat and earthed the black wire which bolts behind it to the frame. This morning i made an earth wire from rec body to frame and it appears to be putting out 14v 😥
Not sure if its cured but new battery will be in tommorow so will find out then!
yep it has an earth, do you not have a wiring diagram for the bike?
Ant P
Have now, thanks to Monty
Bike seems to charge now 😃 Happy days..now its running properly, time to upgrade!
Big thanks to all for help, without this forum my bike would def spend more time in the garage than on the road
Ant P
Power peaking cured!
Beware ccm riders....riding home from the shops the other day my bike decided to try and wheelie into the car in front!! My throttle cable had frayed and stuck open. Brown pants moment and spectacular accidental rolling burnout later i nursed the bike home and checked cable. Pumper carb has arrived so gutted i cant fit it and play as throttle cable now needed
