Wanted:R30 Rotax Front Disc 320mm for mag wheels, and spacer..; to put on my 404
Topic Started: Mar 30 2016, 08:08 PM (503 Views)
BristolDSer
On the tools.
Need a front disc for an R30 mag wheel.
Does anyone know if it's the same for 644's and Rotax?
Does anyone know if my 404 stock offroad disc will bolt on for now?
Also need the rear spacer on the disc side (4mm i believe)
I also need a kind chap with some engineering tools to mill out my internal spacer in the front wheel.
C
Edited by BristolDSer, Mar 30 2016, 08:10 PM.
2005 404e, SM wheels. Carb setup: DXP Needle, 5th clip, 155 main, 42 pilot, 60 pilot air, CE Delete.
whats up with the spacer? too tight for the spindle, I did try it on a spindle and it slid along OK
BristolDSer
On the tools.
Think you confused me for another bloke on here.
I've not picked my wheels up yet
Sorry, did a simular job a while back, made new spacers for mag wheels.
Disc's for mags are very rare to find, though I do think someone found a replacement, its on the site somewhere
found the thread
https://ebcbrakesdirect.com/motorcycle/ccm/r-30-mag-wheel--604-644--front-disc-h/2002-2004/31944
Part No. MD6306D they have one in stock
Edited by Monty, Mar 31 2016, 06:30 AM.
They do come up from time to time on eBay just keep your eyes open
BristolDSer
On the tools.
Mar 31 2016, 06:23 AM
found the thread
No apology required!
How do you feel about doing one for me? Let me know if you can help.
My budget dictates a used disc, one just went for 16 quid, I got outbid.
I assume my stock off road disc won't fit
I dont mind making up spacers, I dont charge a lot. you send me the dimensions you want.
Your stock discs will not fit unfortunatley, mounting holes are different pcd, think the mag has 5 mounts, std are 6.
BristolDSer
On the tools.
Brilliant, I'll be in touch.
I believe it's only the internal spacer from the front that will need boring out a tad to get the spindle through it.
C
I may have the drawing somewhere for the last one I did, though think I just bored out the original. you will probably need a spacer made to do away with the speedo drive, as the 404 has a sensor.
BristolDSer
On the tools.
I'm hoping I can re-use the spacers on the front wheel from my enduro wheels. Apparently all I need is the washer on the back, a bored out internal spacer on the front.
The rest can be re-used from my enduro wheels according to another member whose spacer you bored out.
The mag front wheel spacer on the disc side does not usually come out easily and should come with the wheel as its a tight fit, so hoping you have it, it will then fit straight in with the mag speedo drive or a spacer made to take its place, the rear only has a 20mm washer on the disc side, cant remember but think it goes between the disc carrier and the wheel
BristolDSer
On the tools.
http://pages.ebay.com/link/?nav=item.view&id=371580140421&globalID=EBAY-GB&alt=web
Seems to be missing front disc side. I'll enquire.
