| Crankshaft pulley nut; Sprag clutch repacement | |
| Tweet Topic Started: Mar 27 2016, 11:38 AM (525 Views) | |
| ccmdave68 | Mar 27 2016, 11:38 AM Post #1 |
Hello all, after building up the confidence to replace/repair the sprag clutch/Spring through the use of these hallowed pages, first problem is how to get the crankshaft pulley nut undone???? I've locked the crankshaft, liberally coated said nut in plus gas, bike in gear, brakes on and I still can't get it undone. Using the longest handled torque wrench I have. Any ideas, tips would be gratefully received. |
| Gonzo250 | Mar 27 2016, 02:41 PM Post #2 |
Impact driver or air gun. Possibly with a liberal application of blowtorch on the nut. Be warned, you may well cook up the crank seal... |
| ccmdave68 | Mar 27 2016, 02:46 PM Post #3 |
Thankyou Gonzo, i'll give it ago and let you know how on I get on. Whats the worst that can happen lol!!!! |
| Gonzo250 | Mar 28 2016, 12:01 PM Post #4 |
Good luck! You should see it whizzing off in short order! |
| ccmdave68 | Apr 1 2016, 06:54 PM Post #5 |
Cheers Gonzo, all done, worked a treat. many thanks for the advice Pikey. |
| Gonzo250 | Apr 2 2016, 08:56 AM Post #6 |
Excellent! Glad you're all sorted! |
| Ant P | Apr 2 2016, 11:23 AM Post #7 |
Theres a great MZ how to guide available, ive used it more than i would of like to lol. It may be on here, i,ll see if i can find the link |
| Ant P | Apr 2 2016, 11:25 AM Post #8 |
http://www.mzriders.com/viewtopic.php?f=5&t=3939 Hope this helps 😉 |
| ccmdave68 | May 1 2016, 01:04 PM Post #9 |
Thanks to you all, all done and back on the road.
8:55 AM Jul 11
