| valve clearance | |
| Tweet Topic Started: Mar 26 2016, 02:18 PM (489 Views) | |
| gazc32 | Mar 26 2016, 02:18 PM Post #1 |
hi when you do the valve clearances on a 604 do you do it with the crank locked as though you were changing the belt cheers
| Gonzo250 | Mar 26 2016, 03:26 PM Post #2 |
I haven't, personally. Nor have I ever locked the crank for changing the belt, but that's just me. |
| Monty | Mar 26 2016, 04:15 PM Post #3 |
No need to lock the crank, just set engine to TDC, there is a fair amount of movement either way before it will interfer with your measurements |
| gazc32 | Mar 26 2016, 05:26 PM Post #4 |
thanks lads |
| Lardmarc | Mar 26 2016, 05:36 PM Post #5 |
Jester
On another site I frequent that all use Rotax engines, locking the crank is the first bit of advice you get told on there, even when changing the cam belt. I've never bothered locking the crank as Monty says you've plenty of play before it interferes. |
| Just a flunky along for the ride. | |
8:55 AM Jul 11
