| Ccm 644 centre exhaust pipe wanted | |
| Tweet Topic Started: Mar 22 2016, 06:17 PM (336 Views) | |
| Jaylovesfastbikes | Mar 22 2016, 06:17 PM Post #1 |
Hi I'm after the exhaust centre as mine has split thanks |
| Monty | Mar 22 2016, 07:59 PM Post #2 |
There are two types that I know off, both the same except the front pipe either fits over the out side or fits inside, get it welded up, usually they break (or is brake) on the mount, which I tend to reweld. |
| Jaylovesfastbikes | Mar 22 2016, 08:29 PM Post #3 |
It's on the bracket I had it welded but the guy that did it is a cow boy and it hasn't been tig welded like you ment to do with stainless looks like he mig welded it and it's not fully sealed I could get it re done but someone that I know that builds exhausts but it means postin it I'm in Derby |
| Tramp | Mar 22 2016, 08:58 PM Post #4 |
try someone who does plasma cutting...ive had mine welded a few times when the brackets broke off...or get a stainless sleve for it... or a engineering welding buisness ...call round at tea break or lunch time and ask for a welder...lol |
| Monty | Mar 22 2016, 10:22 PM Post #5 |
I've always used MIG, Its fine with the right wire and gas, I can then if needed grind flat and polish. Any engineering firm will have aTIG & MIG welder, just go to your nearest one and ask |
| « Previous Topic · Wanted · Next Topic » |
8:37 AM Jul 11
