| hard to start | |
| Tweet Topic Started: Mar 18 2016, 04:48 PM (560 Views) | |
| stevo604 | Mar 18 2016, 04:48 PM Post #1 |
I am finding it hard to get my 604 to start brand new lithum battery with 15v showing,click on the decompressor, choke , hit the starter and it does one spin and stops dead same again and the battery dead plus the earth wire gets hot. thought it was a bad earth put a new thicker earth lead on and give it a good earth same thing
| Roadster604 | Mar 18 2016, 06:16 PM Post #2 |
Does it kick over freely, only thinking it could be the starter gear/ starter |
| keep the faith | |
| Monty | Mar 18 2016, 07:37 PM Post #3 |
If the earth is getting hot after one turn, I'd think you have a short cct some where, live cable is not pinched some where or shorting on the starter terminal |
| stevo604 | Mar 19 2016, 10:02 AM Post #4 |
roster604 it had a new sprag and starter gear fitted so I can rule that out monty will go through the loom bit by bit and check it out thanks all question were is the earth wire connected to on the bike mine run onto the cam cap on the engine were is standard fitment
Edited by stevo604, Mar 19 2016, 10:05 AM.
| jonny h | Mar 19 2016, 10:20 AM Post #5 |
there should be a thick earth going from the battery to the frame, about 4 or 5 inches long. when i took my loom apart the other week, that cam cover earth wasnt even connected to anything!! |
| Monty | Mar 19 2016, 10:48 AM Post #6 |
Mine has a large black cable running with the starter cable and bolts to the starter mounting bolt |
| Gonzo250 | Mar 19 2016, 03:20 PM Post #7 |
I've got both. The one from the rocker cover is bolted behind the rear brake reservoir, and the main earth for the starter is (obviously) bolted between starter mounting bolt and battery. I also ran a separate earth from the loom to the reservoir bolt, as well as the one from the loom to the battery. I've learned the hard way that one can never have too good an earth! |
| stevo604 | Mar 19 2016, 05:54 PM Post #8 |
I think I will run mine to the starter mount and keep the one from subframe to rocker cover aswell it seams a lot are earthed different |
| jonny h | Mar 19 2016, 06:38 PM Post #9 |
my starter doesnt have an earth, i guess this is for the later 604's? |
| stevo604 | Mar 19 2016, 11:17 PM Post #10 |
well I have success I ran a earth to the starter mount a hey presto she started first time and settled into a tick over thanks all for the info
| Monty | Mar 20 2016, 08:03 AM Post #11 |
Glad its sorted |
8:55 AM Jul 11
