CCM R30 644 speedo cable; Need one for spoked wheel
Topic Started: Jan 18 2016, 02:37 PM (330 Views)
gmanb1h
Hi all, after a 644 r30 speedo cable for spoked wheel. One from the mag wheel is too short.
Graham_ccm@hotmail.co.uk
Thanks
Grurple
Double post but:
I used one for a yamaha YBR125. It has a kinked connection at one end which fitted nicely at the wheel end.
This one in fact:
http://pages.ebay.com/link/?nav=item.view&id=281892474029&alt=web
gmanb1h
Ta, fitted it but the speedo won't work, I can twist inner and get speedo to move?
Grurple
Can you spin the inner of the cable at the wheel end while the speedo end is connected and get the speedo to move?
(I have used a drill to do this in the past)
If not, it may not be long enough to reach into the speedo. Does it work if you reverse the cable? One end might be longer.
