Wanted 644 head oil feed pipe + mid exhaust + carbs
Topic Started: Oct 28 2015, 10:26 AM (387 Views)
cortinamini
Hello everyone
I'm after a few parts for a 644 suzuki engine ccm
Firstly I'm after the oil feed pipe that runs up the back of the barrel to the head, also attaches to the right hand side casing and the top of the gearbox.
Secondly, The middle section of the standard ccm exhaust, mite consider the front pipe aswell.
Thirdly. A pair of 644 suzuki carbs, not bothered if they need cleaning up, would prefer if the screws are all free, but may consider one's that need work.
Pm me or post on here or email. Cortina.mini@Hotmail.co.uk
Cheers Tom
Edited by cortinamini, Nov 16 2015, 07:32 AM.
Word of caution, there are several versions of the suzy exhaust, so make sure you get the correct mid pipe for your front,
You also have a pm
cortinamini
OK cool, any idea what the differences are? I'm after a r30 one
for some reason the front pipe on version 1 fits inside the mid pipe, on version 2 it fits outside, R30 and DS are both the same, just that later ones had the different joint, some mid sections had a mount that used the top cradle bolt and rear sub frame mount, some just use the subframe mount, both types fit as they are all the same bends.
