koso speedo trouble
Topic Started: Dec 27 2014, 09:58 PM (520 Views)
gasyz
Hi,has anyone had trouble wiring the koso dB 01 plus?
Wired mine as per (shite)instructions and the back light only comes on when you initially turn the key on for a couple of seconds then goes out and the indicator warning light will only flash when motor is running checked and double checked wiring,now a bit stumped. :what:
Edited by gasyz, Dec 27 2014, 09:59 PM.
Never fitted one, but just read the manual and seems simple enough. if it does not work contact the dealer, unit may be faulty,
Are you using led indicators as manual says fit 1/4 watt 250 ohm resistor in parallel
Have you tried riding the bike, the back light may stay on whilst moving, and not when stationary
gman1964
I fitted one to my bandit....make sure the power cable is tapped off the main ignition on wire...which stays live
when turned on....otherwise sounds like yours might be defective....
look online for better instructions....I dounloaded a pdf which was way more detailed then the supplied ones...
houdini
gman1964
Dec 28 2014, 08:58 AM
I have one fitted and it is taken off the ignition i will be fitting a new head light Tuesday can double check for you then
gasyz
I've got one feed off ignition and a permanent through a fuse straight off the battery.my dad has got a koso dB 01r and that wired up no trouble,but this one is the plus model and seems to be a bit different.
