| Snapped head bolt😞 | |
| Tweet Topic Started: Dec 4 2014, 09:26 PM (337 Views) | |
| Lorano | Dec 4 2014, 09:26 PM Post #1 |
My brother is stripping his R30 down and has snapped one of the exhaust bolts in the head leaving a bit sticking out and the other one intact still in the head.Am I right in thinking he could hear the snapped bolt up with oxy/acetylene to help get it out?Anybody had this issue and if so how did you resolve it? |
| Gonzo250 | Dec 4 2014, 09:36 PM Post #2 |
Ally head, probably better to use a regular blowtorch and heat the whole area as evenly as possible. Lots of penetrating oil for a few days prior if you've got the time. And when trying to get it out, GO EASY! Last thing you want is to snap the rest of it off... EDIT: reason you heat the area and not the bolt is that ally expands at a different (faster) rate to steel and you want the head to let go of the bolt. Edited by Gonzo250, Dec 4 2014, 09:38 PM.
| Rob 110 | Dec 4 2014, 09:37 PM Post #3 |
try that or weld a new nut on the stud |
| Monty | Dec 4 2014, 10:20 PM Post #4 |
If all else fails, drill it out and run a tap down the thread, I have done many that way, though its a lot easier with the head off, it can be done in situ |
| snipperuk | Dec 4 2014, 10:35 PM Post #5 |
+1 for slipping a nut over the stump and welding it on :-) as said you can drill it out if it don't work ...cobalt drill bits are cheap enough at toolstation |
| ian6pot | Dec 4 2014, 11:48 PM Post #6 |
I always try the welding of a nut first even if its broken off flush. You also find the injection of heat from the welding help as well. |
| whitebuck | Dec 5 2014, 05:50 PM Post #7 |
Then get a socket on it whilst everything is hot |
1:02 AM Jul 11
