Fuse box/electrics
Topic Started: Dec 3 2014, 11:40 AM (408 Views)
Lorano
Is there any way to protect the electric/fuse box from water?On my ccm DS it looks like water would just piss into the electrics if you were to go mental when washing it😝
ian6pot
There's all sorts of ways ranging from wax spray to a Tupperware box with cable gromets.
ACF 50, when leaving the factory the fuse box did have a lid, but even so .. ACF 50
Mine don't leak when I use the jet wash on it and that's a 3200psi power wash lol
Also some stuff called Gt85
RotaxMatt
DOW Corning Electrical Insulating Compound is good stuff... more for localised insulating though :-)
Lorano
Just seems a bit 'crappy'😔.You remove the plastic cover and all the fuses,relays and stater solenoid are all exposed.No protection from the elements really.
GT85 is not made for the job you have assigned it, ACF 50 has been .. that's it's sole purpose in life .. Aircraft grade non the less. in a place like behind the cover or inside LED rear lights before installing, you would spray it on once a year, if you really want to protect your electrics why would buy anything else?
jay
No protection on mine at all,water pisses in and pusses out just as quick😉
When Rob was leading me through the biggest puddles ive ever seen it was more than my fuse box under water,lol
No failings😃
AKA-THE DUCK
jay
Dec 5 2014, 05:02 AM
No failings😃
Pmsl 😀
Never had a prob with mine either, and its been well submerged totally, I do tend to have a few probs with the regulator failing, only in Wales funnily enough. but on the rotax.
