| Wouldn't start | |
| Tweet Topic Started: Nov 23 2014, 06:45 PM (578 Views) | |
| Lorano | Nov 23 2014, 06:45 PM Post #1 |
Went to go a blast today,pulled the bike out and pressed the start button but nothing😞.Ignition light on,all lights indicators etc working but bike wouldn't turn over.After stripping it apart and getting nowhere I decided to just bridge the start relay to see what would happen and the bike tried to start(battery going flat).Tried with the button again and it tried to start?!Is the start relay bad for sticking or failing?The bike hasn't been started for a few months.The battery is totally dead so Ive got it on charge.The button seemed to work then wouldn't work?! |
| Rob 110 | Nov 23 2014, 07:00 PM Post #2 |
644? yup starter relay probably bad connection green terminals clean and refit if not swap it with the one next to it, as thats sidestand relay (most bypass sidestand switch, so its spare) on a R30 the headlight relay is same too, so its easy to swap and see if headlight still works |
| Lorano | Nov 23 2014, 08:00 PM Post #3 |
I thought the 2 small relays were ignition and side stand.The start relay I'm on about is where the battery lead screws into a terminal and another lead comes off and goes to the starter. |
| Rob 110 | Nov 23 2014, 08:29 PM Post #4 |
oh um yeah quite right http://www.sparesccm.com/images/644DS_Wiring.jpg i've not heard of any failing, but if you bridged it and the bike wanted to start then it would suggest the starter rely clean terminals and charge battery and it'll probably work :D |
| snipperuk | Nov 23 2014, 09:19 PM Post #5 |
do you mean the starter solenoid ? |
| Lorano | Nov 23 2014, 09:38 PM Post #6 |
Yeah,the starter solenoid. |
| 604 kev | Nov 23 2014, 10:07 PM Post #7 |
ride it like you stole it
I had a similar problem with mine turned the key and nothing .no ignition nothing and it had to be on the day I was moving . took me ages to find out starter relay ccm wanted £20 or some thing like that plus had to be sent Spain .took to car shop to see what they had had matched it for me £4 |
| snipperuk | Nov 23 2014, 11:22 PM Post #8 |
search universal starter solenoid on ebay £5 + |
| Monty | Nov 24 2014, 07:00 AM Post #9 |
Be careful as the starter solenoid also has the feed for the fuse box going through it, via the fuse |
| Lorano | Nov 24 2014, 07:16 PM Post #10 |
Thanks for all your replies guys😉.Had the battery charging over night,came home from work and boom...started no problem.Was getting 14.5v when running,hopefully the battery will be ok along with the start solenoid.Ive had bike batteries go flat before and it killed them:-(.Is there anyway to check a battery is good,what should the volts drop to on start up?
Edited by Lorano, Nov 24 2014, 07:35 PM.
| Rob 110 | Nov 24 2014, 08:08 PM Post #11 |
just take a reading off the battery when charged, should be 12.5ish measure it again next day, see what the drop is then if any i use one of them £10 solar trickle chargers on the 644 over winter better to keep the battery trickling over than just stood unused |
2:36 PM Jul 11
