| Mr rob110 | |
| Tweet Topic Started: Nov 17 2014, 07:37 PM (349 Views) | |
| motomaniac | Nov 17 2014, 07:37 PM Post #1 |
What's the stuff you used to make you're bash plate? Can't remember... Also, how easy is it to shape? How do u shape/ heat it? How strong is it? Need to make a mount/ bracket for my rear brake reservoir.... Ta |
| Rob 110 | Nov 17 2014, 08:08 PM Post #2 |
cheap to buy and easy with heatgun, but can blister can't think where the reservoir mounts on a 604?? HDPE is probably ok but Acetal is stronger/harder i put some info here http://allterrainrallychallenge.co.uk/forums/topic/hdpe-users-comments-please/ |
| motomaniac | Nov 17 2014, 09:01 PM Post #3 |
I've got a master cylinder/ reservoir, all in one job from a Kwak kxf450,from several years ago to go on, in place of the crf one which has decided to leak from the seal, but as I'm no longer at home with a garage, I thought the plastic would be easier to work with, once to size, do you reckon I could warm it in the oven and then mold it over it? |
| Rob 110 | Nov 17 2014, 09:16 PM Post #4 |
yes mate oven is good HDPE will be easier than Acetal then you could make a simple press mould: wooden U shape (or whatever) heat plastic in oven: 180c until you see it sag push it into U shape with a block |
| motomaniac | Nov 17 2014, 10:08 PM Post #5 |
Sounds like a plan... Cheers dude |
2:36 PM Jul 11
