| Forks | |
| Tweet Topic Started: Nov 17 2014, 08:55 AM (374 Views) | |
| Tonka | Nov 17 2014, 08:55 AM Post #1 |
Hi all Quick question... Front forks on 604. Conventional or USD? Any real advantages of either? I understand the USD would probably be stiffer from the handling perspective but are the conventional lighter? Any suggestions greatly appreciated :-) I have had USD previously but have always liked conventional looks, just old school i guess. Cheers Tonka |
| Tonka | Nov 17 2014, 08:57 AM Post #2 |
Oh.. anyone use a forum viewer on their mobile devices? iPhone or pad etc? recommendations? Thanks very much |
| hursty46 | Nov 17 2014, 10:37 AM Post #3 |
I just have the Ccm forum saved on my homescreen on my I phone! We could do with a app lol |
| Tonka | Nov 17 2014, 10:42 AM Post #4 |
good plan! ill go with the home screen thingy. i have trouble tuning the pc on let alone creating an app! thanks for that :-) |
| jonny h | Nov 17 2014, 03:50 PM Post #5 |
i'm guessing you have the Paioli's on at the moment, are they gold or blue? i have found the gold to be slightly shorter than the blue. anyway .. it depends what you plan on doing with the bike, if this is purely looks and you only ride on road or light green laning, then stick with the RWU if you fancy doing some proper off roading, with lots of rocky ground on a regular basis then it may be best to upgrade. you will have to get a head stock tube made up, and if you do swap then dont bother with the 43mm WP's. just go straight for the 48mm (fitted to every KTM since 2002) and also grab the top and bottom yokes to fit the new head stock tube into. you will be looking at £500 ish for this swap depending on how cheap you get the parts for, and if they need a service. try to get them off a bike 400cc+ or you'll need to change the springs too. |
| Tonka | Nov 17 2014, 03:56 PM Post #6 |
Thanks Jonny, Not got the bike yet, its going to be in supermoto trim as can't do the rough stuff anymore. Good info though and thanks very much. Currently on the hunt for a 604/636 yr 2000 or slightly before, hence the forks question :-) Cheers |
| jonny h | Nov 17 2014, 04:31 PM Post #7 |
Paioli's blue steel 98-99 gold - 99 WP 43mm - 2000 (in less you grab a REAL R30 race bike then you get the 48mm |
2:36 PM Jul 11
